high pressure fuel pump for injected engine conversion
#1 | |
I bought a 35,000 mile 5.3 liter Vortec engine and acompanying automatic transmission for my 1980 CJ yesterday after giving up on the idea of replacing my original SR4 tranny. I am continuing to do research on this conversion and read that I will need to have a high presure fuel pump to deliver fuel to the injector rack. One suggestion was that I could find an external high pressure fuel pump with an aluminum finned body to disipate the excess heat of maintaining the high pressure as opposed to the "in the tank" models that use gasoline to cool the pump in the tank. I understand that "in the tank" model fuel delivery systems also have baffles in the tank to keep a constant supply of fuel to the pump and to the rack if in an incline since air in the system is not a good thing to have. -
-Question----Has anyone used an external high pressure pump successfully or would it be better to buy a used fuel tank from a later model Jeep already setup with internal pump and baffling(assuming this is the stock Jeep setup???)---regards, Mayo
#2 |
I run a Airtex E8248 electric in-line pump with my 1997 5.7 vortec. I have it installed on the frame next to my park brake cable holder. I have duel Flowmaster mufflers that run within 3" of the pump and have a heat shield between them. I have been running this for a year and never had a problem on the street or hard trail use. I was mostly concerned with a "heat" problem, but it's worked great.
#3 |
I use an external high pressure pump for my fuel injection. Its an E2000 from old Fords. Its good for something like 100 PSI. I havent had a prblem with it so far. Its just mounted on the frame rails as fasr back to the tank as it will go.
#4 |
I'm using E2182, capable 50GPH @ 110PSI, mounted on the frame just outside the fuel tank, about two feet from the exhaust tail pipe, no heat shield and it's working perfectly for a year now.
The pump is available at most parts stores and cost about 90$. The advantage of the E2182 over other pumps, especially the E2000, is the 1/2 inlet, as opposed to 5/16 (e2000) or 3/8 at other pumps. The larger inlet allow better/easier priming. The pump doesn't need aluminum finned body, the extra fuel flowing throe it cool it down. Stock Jeep 4.0L pump is capable of 21-24 GPH, the extra capacity of the external pumps cool it down. ![]()
84 CJ7 , Dana 44 rear D30 front, 258, 4.0 head, MPFI, e-fans, T176, Dana 300, 31x10.5x15 and Mustang hydroboost. My esnips folders:Jeep Jeep Transmissions |
#5 |
one more question for Coas
Thanks to all that responded, gave me a start to do somemore digging on the subject. I have one question for Coas? My 1980 CJ7 obviously has no internal pump in the original tank, --will the E2182 or larger models self prime if attached at the lowest point in the frame rails or would i have to also install an inline hand pump like in the diesel setups I use to re-prime the system when I change diesel filters. ---Mayo
"The advantage of the E2182 over other pumps, especially the E2000, is the 1/2 inlet, as opposed to 5/16 (e2000) or 3/8 at other pumps. The larger inlet allow better/easier priming. The pump doesn't need aluminum finned body, the extra fuel flowing throe it cool it down. Stock Jeep 4.0L pump is capable of 21-24 GPH, the extra capacity of the external pumps cool it down." |
#6 |
No need for additional pump. Any of the pumps mention here can do the job as stand alone pump.
84 CJ7 , Dana 44 rear D30 front, 258, 4.0 head, MPFI, e-fans, T176, Dana 300, 31x10.5x15 and Mustang hydroboost. My esnips folders:Jeep Jeep Transmissions Last edited by coas; 12-07-2008 at 03:34 PM.. |
#7 |
great!
Thanks for the info, I am now a man with a plan, thanks again. I always appreciate when i don't have to reinvent the wheel in one of my projects,--kind regards, ----Mayo
#8 |
I put a vortec 5300 in my jeep last year. I ended up running a walbro 255lph external pump. As for baffeling in the tank I ended up just running a fuel cell with built in baffles and foam everything has worked out good so far had it on some serious inclines.
79 CJ-7 5.3L Vortec SM465 (Muncie Rock Crusher) Dana 300, 35x12.5x15 MT Dana 44's Locked front and rear SOA with wrangler springs,Custom roll Cage |
#9 |
off thread, but--
Are you pleased with the 5.3 Vortec and automatic tranny conversion in your Jeep, ----any regrets, things you would do differently if you had to do it over again???-----Mayo
#10 |
I needed to increase the size of the fuel return line as it caused me back pressure, that causes the fuel pressure to move around with throttle , not a good thing for EFI.
Jim |
#11 |
aka Mike
sorry for being late to the party.... i used Accel from summit.... biggest thing to remember is you have to supply 60psi to the inlet for the vortec motor or you will trip a low fuel PSI DTC.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 33x10.5x15 BGF TA KO on Crome Modular rims. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX. Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love. http://main.nationalmssociety.org/site/TR/Walk/VABWalkEvents?px=6419856&pg=personal&fr_id=18331 |
#12 |
coas (et al) - I plan on using your set up for my 4.0 swap. Can I use the stock metal fuel line or do I need to buy a replacement to get me up to the engine? If I do, any recommendations?
What regulator did you use? Can you specify what filters as well? I'd really like to copy a known good set up.
______________________________________ In Process: 2002 4.0L and NV3550 Swap Last edited by whittlecj; 12-10-2008 at 12:57 PM.. Reason: Add more questions |
#13 |
The stock fuel line is 5/16 and it will do fine, if you have the time you can install a new 3/8 fuel line but it's not an easy task with the tub on.
Your setup is OBD2 meaning no regulator at the fuel rail, mine is OBD1, the regulator is part of the fuel rail. Hesco sale the right regulator for your setup or you can get WJ fuel filter/regulator from any part store. ![]() The filter I'm using is stock YJ filter, it has 3/8 inlet and 5/16 outlet which ensure a good flow for the FI and minimum pump load. The pre pump filter is G3 or G15.
#14 | |
Jim |
#15 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
OK, I redid all my lines and am redoing them a second time in the next month (rusted out) and thought I was really sure the stock Jeep fuel line was a 3/8" from the tank to the pump and 5/16" for the return line....
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
