high performance fuel pumps - JeepForum.com
post #1 of 7 Old 05-07-2013, 07:50 PM Thread Starter
sundownbrown
What kind of high performance fuel pumps do yall have on your straight 6's? Thanks
sundownbrown is offline
post #2 of 7 Old 05-07-2013, 08:06 PM
firemanjim7
1983 CJ7
I'm pretty sure unless your running a fuel injected system a stock manual pump will deliver enough fuel to a whatever you do to you 258. Most of the time it delivers too much. That's the reason for the bypass fuel filter.
firemanjim7 is offline
post #3 of 7 Old 05-08-2013, 04:49 AM
BagusJeep
1981 CJ7
If your pump delivers more than about 6psi then even with the 3 way fuel filter and tank return you are capable of overwhelming the carb's inlet valve.
The standard mechanical pump is well up to the job, especially with the filter fitted.
Some members fit strong electric pumps but after a few feet then install fuel pressure regulators. Seems a bit of a waste to me.
Puthijeep has an electric pump, it is made by Denso and goes clunk, clunk, clunk. It must have cost $10.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 7 Old 05-08-2013, 06:56 AM Thread Starter
sundownbrown
Thanks for the respnses, maybe my carb is the issue
post #5 of 7 Old 05-08-2013, 09:28 AM
bkeese
1949 CJ3A
If it is a bbd then you answered your own question.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #6 of 7 Old 05-08-2013, 11:19 AM Thread Starter
sundownbrown
what is a bbd?
post #7 of 7 Old 05-08-2013, 04:31 PM
7179CJ5
1979 CJ5
bbd carter carb?
7179CJ5 is offline
