high out put coil - JeepForum.com
post #1 of 10 Old 06-11-2002, 09:32 PM Thread Starter
KG4PAM
Post high out put coil
any one have a suggestion as to what high output ignition coil is best? i am hoping that a better coil will increase my power/milage/emissions. thanks all!
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #2 of 10 Old 06-11-2002, 10:49 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by KG4PAM:
<strong>any one have a suggestion as to what high output ignition coil is best? i am hoping that a better coil will increase my power/milage/emissions. thanks all!</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">When my 304 started getting tired I kept it around a few more years by installing 8.8 mm wires and an Accel 50,000 volt super coil. I also had great results with the MSD Blaster II coil at 40,000 volts. Now I have a fresh engine I've gone back to the stock 20,000 volt coil.
Steve
OldJeepguy is offline
post #3 of 10 Old 06-12-2002, 03:26 AM
cj7traildriver
Post
Basicly a high output coil is pretty simple in design any should be sufficient thru most any manufacturer MSD and Accel are good products and coils alone are not overly pricey. May also want to look into there ignition sytems can double shoot a spark usualy up to 3000 rpm.
Jeep what else matters.
cj7traildriver is offline
post #4 of 10 Old 06-12-2002, 08:48 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
Just as a point of information, I just ripped off a Brand New Accel Super Coil from my '72 AMC 360 and put on a stock coil from NAPA, and it runs much better now. For some reason, the coil was causing 3 of my cylinders to misfire, as I found out with a timing light, and at many times any given cylinder of those particular three would not fire at all for several minutes.
I'm sure it was defective, and not all of them are like that, but it is yet another "non-success" story of my experience with Accel. I would personally stick with quality names like MSD or Jacobs, etc. if you want good quality and reliability.
Once I isolated the coil problem, I also went and changed the Brand New 8mm Accel wires the previous owner had installed and went back to plain old 7mm Beldens from NAPA. I have used Beldens for many years, and have never had to replace a set on any vehicle due to wear/tear or being defective.
Just a point of info.
4wheeler4CJ is offline
post #5 of 10 Old 06-12-2002, 04:00 PM
Boggy Bottom
Post
I totally agree. Accel was once the superpower in performance ignition. Now they are less than desirable. I have an Accel coil on one of my rigs, but only because it came that way. Mallory, Belden, MSD... all good!
Ol' Boggy Bottom
'83 & '84CJs, '51, '53, and '57 Willys Pickups
Boggy Bottom is offline
post #6 of 10 Old 06-12-2002, 04:03 PM Thread Starter
KG4PAM
Post
how about HEI or (TFI, is that right,or is it EFI ?), would i be better off converting to one of these ignitions?
KG4PAM is offline
post #7 of 10 Old 06-13-2002, 08:24 AM
4wheeler4CJ
Arrow
Hell, yeah, HEI is a great easy conversion. You can also go with Mallory DUI, designed for use with AMC motors. A bit pricey for the new distributor setup, but a simple one-wire hookup, and parts are interchangeable with GM HEI, as I understand. Check out
<a href="http://www.4wd.com" target="_blank">www.4wd.com</a> or <a href="http://www.quadratec.com" target="_blank">www.quadratec.com</a>
I know one or both of these guys carries the systems. <img border="0" title="" alt="[Wink]" src="wink.gif" />
post #8 of 10 Old 06-14-2002, 08:32 AM
Bulletproofcj7
Post
I have the D.U.I. (Davis unified ignition)H.E.I, It Works great! and a snap to install!
My only Question, Is it compatible with those aftermarket fuel injection systems? does anyone run a howell or holley projection?
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #9 of 10 Old 06-14-2002, 07:45 PM
Bob K
Bob K's Avatar
Thumbs up
The JuiceBox TFI
<a href="http://www.driveajeep.com/tfi/index.html" target="_blank">http://www.driveajeep.com/tfi/index.html</a>
Best $130 I ever spent on my Jeep. high quality, easy installation. Gives as much zap as you'll ever need unless you're running a hi-po cam and/or some other goodies.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #10 of 10 Old 06-16-2002, 06:35 AM
West
Post
An MSD Blaster 2F is a good choice too since it uses the same horseshoe connecter as a stock coil.
West is offline
ultra coil and ignition system or oem coil? bmorrow Jeep CJ Forum 12 05-04-2010 12:48 AM
CANISTER COIL or E-core coil for team rush? imtheant Jeep CJ Forum 10 05-27-2009 01:45 PM
which coil do I buy jksull Jeep CJ Forum 2 04-13-2008 08:54 PM
Ford TFI coil or MSD coil? b.d.d. Jeep CJ Forum 6 10-28-2007 07:07 AM
Prob W / Coil wire/Coil pack & Steering Colum dcomb Jeep CJ Forum 5 08-23-2007 03:28 PM
