High brake pedal - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > High brake pedal
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki50" white/amber dual-color LED lights bars for $349 S
Unread 06-14-2015, 05:57 PM   #1
Bacon16
1978 CJ5
High brake pedal
my 78 cj5's brake pedal sticks out about 4-5 inches further than the gas pedal. In or order for me to press the brake I literally have to lift my leg up, bring my knee towards my chest to allow my foot to clear, and not get my toes caught on the back side of it.
Any suggestions on lowering it to a little more flush with the rest of the pedals?
Thanks!
Bacon16 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 05:21 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Nope, that is how vehicles are made. Not only does the height difference make sure you can't easily put both the brake and gas on at the same time, the brake pedal needs the travel to be able to push the pads and shoes far enough to grab in a controlled way.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 06-15-2015, 07:39 AM   #3
WindKnot
WindKnot's Avatar
1977 CJ7
I've got to go with what Mike wrote. The pedal is directly connected to the master brake cylinder piston rod.
The CJ is a very simple machine that's not designed for speed shifting or braking. (Oh who am I kidding? It's not designed for speed. Period.)It's not a modern speedster where you can just pivot your foot with your heel. What you describe is normal Jeep (or even pickup of the era.)
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 04:10 PM   #4
Partsmke
Thanks!
Change it over to power brakes the pedal is much lower.
Partsmke is offline   Reply With Quote Quick reply to this message
Unread 06-16-2015, 05:30 AM   #5
Mike Romain
Really? Is that on a 5 only? I have power and a friend has manual brakes in our CJ7's and the pedals are enough the same we can't see any difference.
Even so, power brake pedals are the same deal, they are higher than the gas so you can't put both on at the same time by mistake.
Mike
Unread 06-17-2015, 03:18 PM   #6
Bacon16
1978 CJ5
I drove it around today and perhaps I am just accustom to my G37 daily driver (obviously sportier than an old jeep) that the distance seems extreme. There is certainly no way for me to press them at the same time with the same foot (not even close), I really don't know if mine has always been like this or at some point in its life something was changed.
Personally, the gap is enough for me to actually fear that I won't be able to get my foot to the brake quickly if I needed - that or get my foot caught on the back of it.
I'll be installing a power brake booster soon - maybe that will lower it some? Either way I'm tempted to cut it, weld a 1-2in steel piece to sink the pedal a pit closer to the floor.
Anyone's thoughts on that?
Unread 06-17-2015, 06:55 PM   #7
Partsmke
You can lower the pedal by using a shorter rod that attaches to the pedal. You should add something to block the return of the pedal that the return spring can use as a stop.
Unread 06-17-2015, 07:10 PM   #8
John Strenk
John Strenk's Avatar
1976 CJ5
It should be the same height as the clutch pedal.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 06-19-2015, 07:33 AM   #9
bdatkins
1978 CJ5
I always find it amusing when (the rare occasions) I let a friend drive mine and almost every time someone says says something about the height of the brake pedal. I don't even notice it anymore. I did shorten my accelerator cable because I wasn't getting my webber carb fully opened (I drove that thing for years without ever opening the second barrel!) so that actually raised my gas pedal up some. Otherwise, my setup looks like the picture John posted. Miscellaneous loose hardware on the floor and all!
bdatkins is offline   Reply With Quote Quick reply to this message
Unread 06-19-2015, 01:58 PM   #10
GB3440
GB3440's Avatar
1979 CJ7
X2 on the pedals on my 7. They looks like John's as well. Although, I have to admit, he has help with his (emergency) brake pedal height. Nice bungee!
The inherent vice of capitalism is the unequal sharing of blessings; the inherent virtue of socialism is the equal sharing of miseries. - Sir Winston Churchill
GB3440 is offline   Reply With Quote Quick reply to this message
Unread 06-19-2015, 04:21 PM   #11
RedNeckCorvette
1979 CJ7
When I seen the post about power brakes and peddle height, it was my recollection, having installed an original 1979 OEM vacuum booster, there was no difference in the peddle height.
RN
RedNeckCorvette is offline   Reply With Quote Quick reply to this message
Unread 06-19-2015, 06:56 PM   #12
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
On my power brake CJ7 the brake pedal at rest is a little lower than the clutch pedal. It's always been that way.
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is offline   Reply With Quote Quick reply to this message
