| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Sandman
High altitiude timing and "Nutter Bypass"
97 TJ 4.0 5 speed, 33" on 15's 4" Lift with 4.56 gears. 85 Cj7 258 - TF 727 3 Speed Automatic. New Weber 32/36 . Still a work in progress. |
#2 |
I live at 7200 and set mine at 12 bdc. At 2500 I wouldnt touch it. I see you have a weber 32/36. You may want to buy an altitude jet kit and bump your air jet up 3 sizes or your primary idle down 1 size. The webers run a tad rich anyway so the difference between sea level and 2500 and the tendency for webers to run rich might give you a little better performance.
You can test this by your lean best idle mixture. If the screw is out more than 2 turns you may want to consider it.
Weber 32/36 DGEV, 4" Suspension Lift , 1 " body lift 8000 lb Winch, 20 pound CO2 (onboard air). TeamRush ignition upgrade with MSD 6a CDI Dual Batteries KC Daylighters Cold Air Intake Lock-Right Lockers Yukon 1 piece axles Custom Bumper& Swing Out Tire Carrier Mile Marker Hubs |
#3 |
Sandman
This Carb swap has been a real bugger. My idle mixture screw is out 3 turns and my idle screw 3 1/2 turns
#4 |
Try adjusting the timing advance a little at a time till it pings, then back it down. You may need to adjust it again later after it gets real warmed up.
#5 | |
Idle speed screw should be about 1.5 in +- 1/2 turn. From that point adjust your idle mixture. here is the link for the adjusting procedure. I would reccomend starting all over on adjustment. At that point you can decide if you need to re-jet CARBURETOR SET UP AND LEAN BEST IDLE ADJUSTMENT
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Nutter bypass timing curve | primezero | CJ Technical Forum | 24 | 10-17-2009 10:37 PM |
| Question after "NUtter Bypass" | CJ8Extreme | CJ Technical Forum | 1 | 10-07-2009 09:35 PM |
| "Nutter Bypass" Do I need to do it? | Donobrew | CJ Technical Forum | 20 | 05-21-2009 02:17 PM |
| The "Nutter" Bypass | nichols077 | CJ Technical Forum | 20 | 01-28-2008 08:10 PM |
| MC2100 and the "nutter" | petey156 | CJ Technical Forum | 3 | 11-29-2005 11:40 AM |
The time now is 09:54 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
