Hi Steer Knuckle Question - JeepForum.com
post #1 of 18 Old 02-12-2013, 01:27 PM Thread Starter
TIPPEDITOVER
At the Mall
TIPPEDITOVER's Avatar
1978 CJ5
Hi all, so I'm hoping maybe you knowledgeable folks here can help me identify what flat top knuckles I have based on the part number of "620243" cast into each of them. I was told the housing they're on is a d44 from a dodge. I don't think I'm gonna run them for two reasons.
One: I doubt they'll work with my chevy small bearing spindles and caliper brackets
Two: they look kinda thin and weak in certain areas. Any help identifying these would be greatly appreciated. If needed I can get a photo up.
They have a typical 6 bolt chevy disk brake spindle pattern. I'd run them if you guys thought they'd be good enough, if my small bearing spindles and brakes will fit them. They just look kinda thin in areas.
I also have a mid 70's drivers side flattop chevy knuckle and it's got way more beef, but I only have the one. I need a passenger side to match it.
TIPPEDITOVER is offline
post #2 of 18 Old 02-12-2013, 01:51 PM
82JeepCJ7
1982 CJ7
Tipped, I would use the Dana 44 flat top knuckles. There is a lot more material where the high steer arm would mount. Check out www.nw-wheelers.com
They are a local board and I know someone on there has a set they will let go for a good price.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 18 Old 02-12-2013, 02:08 PM
CSP
Might find some relevant info here: http://77cj.littlekeylime.com/flatop_knucles.html
Your spindles would work on them, but the Dodge knuckles have the caliper mounts as part of the casting and Chevy calipers aren't compatible with the mounts.
Chevy knuckles aren't hard to find. The plus side is the drivers knuckle you have should be milled/drilled/tapped already for a high steer arm.
CSP is offline
post #4 of 18 Old 02-13-2013, 01:55 AM Thread Starter
TIPPEDITOVER
At the Mall
1978 CJ5
I have drilled and tapped flattop knuckles. "620243" cast into them, what are they?
post #5 of 18 Old 02-13-2013, 10:03 AM Thread Starter
TIPPEDITOVER
At the Mall
1978 CJ5
Well I'm still hoping someone will chime in and help me figure out my knuckle dilemma. I've searched high and low, came up with nothing for that part #.
post #6 of 18 Old 02-13-2013, 10:09 AM
CSP
You might try posting a picture. I have no idea what casting numbers are for the knuckles I can recognize visually.
CSP is offline
post #7 of 18 Old 02-16-2013, 03:05 PM Thread Starter
TIPPEDITOVER
At the Mall
1978 CJ5
I'll do it. I just need a little more time. I'm welding the inner knuckle I pounded on last night.
post #8 of 18 Old 02-17-2013, 04:28 PM Thread Starter
TIPPEDITOVER
At the Mall
1978 CJ5
Here's photo's of the knuckles. They don't look nearly as strong as the one driver side flat top chevy knuckle I have. I need a passenger side chevy flat top. Just got back from the picknpull. Not a single one to be had
post #9 of 18 Old 02-17-2013, 09:12 PM Thread Starter
TIPPEDITOVER
At the Mall
1978 CJ5
Here's more info. I need a knuckle specialist please. These are confusing me.
post #10 of 18 Old 02-17-2013, 09:38 PM Thread Starter
TIPPEDITOVER
At the Mall
1978 CJ5
I'm one step closer to knowing what they are. The CJ5 Dana 30 knuckles looks identical. The difference is the CJ5 D30 knuckles have their caliper mounts cast into the knuckle itself. Well my question is answered well enough based on this new information. It's basically a Dana 30 knuckle. End of story.
post #11 of 18 Old 02-17-2013, 10:05 PM Thread Starter
TIPPEDITOVER
At the Mall
1978 CJ5
Got tired of goofing off. Found a beef Chevy pass-side flat top sandblasted, painted, milled, drilled and tapped for 150 + shipping of $14 outta Oregon City, Oregon. Be at my door in a few days. Done and done. I see 1.50" diam x .250" wall DOM in my near future. Life is good. I now have a set of flat top Dana 30 knuckles for sale. What they fit, who knows? If anyone's interested, pm me, thanks!
post #12 of 18 Old 02-17-2013, 11:01 PM
82JeepCJ7
1982 CJ7
That odd knuckle with the flat top is not from a Dana 30. All Dana 30 knuckles were round on the top.
post #13 of 18 Old 02-18-2013, 05:34 AM
nshefbuch
1982 CJ7
1976 D44 is the only Chevy I know that came factory with both knuckles flat top.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #14 of 18 Old 02-18-2013, 08:04 AM Thread Starter
TIPPEDITOVER
At the Mall
1978 CJ5
Yeh their an odd looking pair of knuckles. Not totally d30, not fully d44. Somewhere in between. I suppose that makes them somewhat of a novelty item? Haha, oh well. I'm glad to be past this phase of the axle build.
post #15 of 18 Old 02-18-2013, 10:43 AM
82JeepCJ7
1982 CJ7
I've been looking around about them odd knuckles. From what I can can find, they are from a drum brake Dana 44. Disc caliper mounts and dust shields won't fit on them.
