hi.. some advise on a knock... - JeepForum.com
post #1 of 6 Old 05-28-2003, 10:27 AM Thread Starter
oldtimer
im not sure what j of jeep i have..its a old 90 wrangler, 4cly 5sp..
it has 200k on it and still goin strong every day...anyways...
ive noticed a slight tap or knock when i turn the wheel left or right..seems to be coming from the wheel area.. seems a bit more pronounced on the right turn... what would this be...
oldtimer is offline
post #2 of 6 Old 05-28-2003, 11:23 AM
BIGJMCCONNELL
1977 CJ7
Welcome oldtimer,
You have a YJ just for future reference.
Sorry I can't say for sure what your problem is but my guess would be a front axle u-joint. Maybe someone else will have another idea
--BIGJ
1977 CJ-7 with Ford 302 engine
2.5 inch springs Matkins Frame with 1.5 inch body lift and all Fiberglass body D30/M20 w/3.54 gears, Moser 1-piece and Rear Aussie Locker, Jeep T-18w/Dana 20 and 35" tires Dual Flowmaster Exhaust, 6 point roll cage, OBA and a bunch of other stuff.
BIGJMCCONNELL is offline
post #3 of 6 Old 05-28-2003, 11:24 AM
fuzz401
1978 CJ7
could be a u joint in the axel or a bearing in the frount end some were
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #4 of 6 Old 05-28-2003, 11:25 AM Thread Starter
oldtimer
knock..
thats probly right... ill check them for play...thanks for the info!
oldtimer is offline
post #5 of 6 Old 05-28-2003, 01:08 PM
only in a jeep cj
With the engine running for the power steering, have someone turn the wheel back and forth to make it knock, while your underneth or up front checking the sound. I found mine to be a slight shift of a front spring at the main eye bolt. Unless your hand/ ear was there, you couldn't tell where it was comming from, but you sure could feel/hear it threwout the whole Jeep.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #6 of 6 Old 05-28-2003, 02:15 PM Thread Starter
oldtimer
good point!
ill get dirty....heheheh
oldtimer is offline
oh no, is it rod knock? trw Jeep CJ Forum 16 07-26-2010 04:31 PM
Korando? CJ Knock off? See for yourself. HandyAndy516 Jeep CJ Forum 50 08-17-2009 03:22 AM
Engine knock in my 258 red240z Jeep CJ Forum 0 04-06-2009 08:12 AM
AMC 258 knock RVC Jeep CJ Forum 14 03-13-2009 12:31 PM
Engine knock cj7roaddog Jeep CJ Forum 14 02-29-2008 10:12 AM
