Hi-Lift mounting base - JeepForum.com
post #1 of 4 Old 06-28-2002, 09:37 AM Thread Starter
GabrielCJ7
Post Hi-Lift mounting base
Hi there again, im working in my cj7s chassis erasing any rust it have, im going into a 60" Hi-Lift, and need help about how it can be installed, i would prefer mounted in the back side, near the spare tire, is this a good position??? but need info about, thxs a lot.
81 CJ7 258 6 cyl. 4 spd tranny 35 BFG mud terrains soft top RS9000s shocks(BLACK HERMAN)
GabrielCJ7 is offline
post #2 of 4 Old 06-28-2002, 11:51 AM
Steelhead
Post
I wouldn't get a 60" high lift if it were me, I have a 48" high lift and have never needed more lenght. A 60' high lift would have to be mounted verticle and you most likely would have problems with overhead clearance like fitting into a garage or parking facility. I have my 48" mounted verticly and I can fit into my garage and parking facilities with out any problem.The only other way that I can think of to mount a 60" without any clearance problems would be to mount it on an angle putting the base at the rear of the Jeep and the top angled and connected to the top of the roll bar. Off hand I don't know if this would interfer with a top though.
Steelhead is offline
post #3 of 4 Old 06-28-2002, 02:09 PM Thread Starter
GabrielCJ7
Post
Thanxs Steel, ill think about it, and one more question 48s enought for this tire size (35)???, the need of hi-lift is only in case of lift the jeep not heavy 4x4 use...
post #4 of 4 Old 06-28-2002, 02:58 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
I ageee w/ Steelhead. 48" is plenty. You should anyway be lugging around a good pice of all-purpose 4x4 scrap wood (mine's pressure treated - my tub is rotting faster than it). This not only serves as helpful base, but that's 4" extra inches of lift if needed. A good wood block has about 100 other uses or so once out and about.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
leaking from base of distributor? atomicflatulenc Jeep CJ Forum 10 07-12-2008 02:21 PM
Wider Axle Base? a_wild1 Jeep CJ Forum 13 04-22-2006 01:16 AM
CJ-5 Wheel base ??? 79'CJ-5 Jeep CJ Forum 7 06-16-2005 06:26 PM
base of windshield weatherstipping NJCJ7 Jeep CJ Forum 2 02-18-2004 10:01 AM
hi lift jack mounting Darko Jeep CJ Forum 17 12-15-2001 10:40 AM
