I read your reply to one of the CJ ignition problems and realized you could probably answer my problem ! 1977 CJ 5 304 V8 with standard prestolite distributor (rebuilt) I have done all the things you advised inone of your threads and still runs like crap ever since I installed this rebuild. I am thinking the reluctor could be mounted on the shaft in the wrong position. The rotor points exactly between 2 of the reluctor fingers .Is this the correct position?
grampsalso
grampsalso
