Hey fellas, How do you install the rod links kit clutch linkage - JeepForum.com
post #1 of 7 Old 03-28-2015, 10:26 PM Thread Starter
agear
I bought the ROD LINKS clutch rod and linkage kit ( with the heim joints you know). I got the rod installed okay. But have no idea how the clutch linkage is supposed to install. It just has a heim joint on one end and the other end is threaded. Was it supposed to come with a bell crank bracket or something or how does this thing go on ? I imagine the heim joint gets attached to the bell crank with a bolt. But I'm sure the threaded end of the linkage does not just go into the clutch fork so I tried to transfer over my end from my old clutch linkage but now it's too long to fit.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 7 Old 03-29-2015, 05:51 AM
keith460
Jeep. There's Only One
keith460's Avatar
I have the same setup on my 84.
Use a bolt, preferably a Shoulder Bolt, through the Heim Joint or Rod End and attach it with a locknut. The threaded end of the Rod End should be 3/8-24 fine thread. You can use a piece of all-thread to screw into the Rod End and lock in place with a 3/8-24 nut. Screw on another 3/8-24 nut, followed by the OEM hex adjuster. The other nut will lock and hold the adjuster in place after you adjusted for proper clutch pedal "free play". It's a good idea to install a small rubber piece at the end of the hex adjuster to prevent noise from the clutch linkage being pushed in and out. The factory installed one is seen in the photo below. A short piece of vacuum hose works good.
1984 CJ-7 Renegade
keith460 is online now
post #3 of 7 Old 03-29-2015, 07:21 AM Thread Starter
agear
Okay so I may have to remove the piece of all thread from the rod links linkage and get a shorter piece because its too long............
agear is offline
post #4 of 7 Old 03-29-2015, 09:47 AM
I6CJ7
Just use a hacksaw and cut it down to size
I6CJ7 is offline
post #5 of 7 Old 03-30-2015, 02:34 PM Thread Starter
agear
Should the kit have come with a bell crank ? Because my old linkage has a notch in it for a ball on the bell crank
agear is offline
post #6 of 7 Old 03-30-2015, 08:00 PM
keith460
keith460's Avatar
No bell crank with kit, that's a separate item.
The ball studs should fit into a plastic bushing in the bell crank, held in place by a wire clip.
1984 CJ-7 Renegade
post #7 of 7 Old 04-02-2015, 07:19 PM Thread Starter
agear
I see what the problem was. There was a ball stud thing that bolted to the bell crank and went in the socket of the linkage. I just have to loosen that off.
agear is offline
