Here's a mystery - JeepForum.com
post #1 of 4 Old 05-03-2010, 10:39 PM Thread Starter
SST4530
1979 CJ5
Here's a mystery
So I pulled the head off my 79 CJ-5 4.2, engine would start and run fine. Installed new head and now there is no spark. Have 12 volts to the coil, haven't checked the ignition module yet. Any ideas???
There is absolutley nothing related to the ignition that requires removal to perform a head swap except unplugging the spark plug wires.
1979 CJ 5 4.2 / T150 3 spd / Dana 20 T-case / 4" lift / 33x13.5-16 Swamper LTB's
SST4530 is offline
post #2 of 4 Old 05-03-2010, 11:49 PM
tcl632
1983 CJ5
Not to sound stupid but check your fuses I changed fuel sending unit and lost fire changed coil relays spent bout 100.00 and still no fire then checked fuses and the problem was a 25amp fues. I have learned from this web site to check the simple things first and then move up from there.
tcl632 is offline
post #3 of 4 Old 05-04-2010, 05:30 AM
ctm
do you have a ground strap running to the head
ctm is offline
post #4 of 4 Old 05-04-2010, 11:10 AM Thread Starter
SST4530
1979 CJ5
Don't beleieve there is one, didn't disconnect when removing. l agree there should be one though.
Haven't checked fuses yet, started to do that last night until I hit my head on the dash so decided to wait till today for that one.
Problem solved, scapped the old ignition and bought a new GM HEI for 4.2
SST4530 is offline
t-90 lever mystery barlow Jeep CJ Forum 3 01-22-2010 12:15 AM
Mystery hose? scooter Jeep CJ Forum 9 12-16-2009 09:25 AM
Mystery CJ7 Part....Maybe hfjeff Jeep CJ Forum 12 10-13-2008 10:06 PM
Mystery Carb? ollietonk Jeep CJ Forum 2 11-30-2006 06:31 PM
mystery noise brak Jeep CJ Forum 9 07-17-2006 04:57 AM
