HERCULINER - JeepForum.com
post #1 of 4 Old 01-15-2002, 02:34 PM Thread Starter
OlllllllO JEEP
Post HERCULINER
I am wanting to make my fiberglass tub a little more sound proof...Is a Herculiner bedliner a good way to go about doing that? Or should I just order a carpet to install. I haven't installed seats or rollbar yet so either would be easy to apply. What about applying a Herculiner and THEN adding the carpet? pointless? I'm just looking to deaden road noise so I can hear my headers better.
1980 CJ7...304 Automatic...few mods. Edelbrock intake and 4bbl...headers. Nothing major...but it is a JEEP!
OlllllllO JEEP is offline
post #2 of 4 Old 01-15-2002, 02:58 PM
Wicked YJ
Post
If you want a quiet ride I suggest that you go with the carpet, it would deaden the noise more.
94 Red YJ
4" RE lift, 2" body lift, 4.10 gears, ford 8.8 in the rear, powertrax No-Slip in the rear, lockrite in the front, complete custom roll cage by Carolina rock shop, and corbeau seats and 5pt. harnesses, and of course herculined
Wicked YJ is offline
post #3 of 4 Old 01-15-2002, 04:38 PM
evilpsych
evilpsych's Avatar
Post
actually.. both would be good.. however.. the herculiner wont do as good a job deadening the noise as rhino lining, unless you spray it in rather thick. my YJ has the carpet liner, but with the regular metal body, and it doesnt help all that much. I'm planning on rhino lining it sometime this summer.. should help out loads.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #4 of 4 Old 01-18-2002, 07:45 AM
AeroViper1
Post
What are the main differences between Herculiner and Rhino lining? Which is more $$$? What kind of application time?
AeroViper1 is offline
Herculiner VS POR-15 VS Nothing dhood Jeep CJ Forum 2 02-15-2008 11:57 AM
Herculiner Aggie99 Jeep CJ Forum 9 12-30-2007 10:23 PM
How much Herculiner will I need? supraman1990 Jeep CJ Forum 3 04-04-2007 09:47 PM
herculiner frankinjeep Jeep CJ Forum 25 06-24-2006 11:19 AM
herculiner petey156 Jeep CJ Forum 3 01-25-2006 11:40 AM
