Quantcast Herculined the tub today...I got pix - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Herculined the tub today...I got pix
GR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent Prices
Old 05-04-2007, 03:25 AM   #1
green cj 78
1978 CJ7
it took alot of prep, but heres what I got.
78 CJ7
5.3 Vortec, T18, Dana 20, AMC 20, Dana 30
97 XJ 2wd POS.
green cj 78 is offline   Reply With Quote
Old 05-04-2007, 06:12 AM   #2
Rookie130
1983 CJ7
I love how Herculiner looks!
Any tricks of the trade, or pitfalls you want to share?
Rookie130 is offline   Reply With Quote
Old 05-04-2007, 10:08 AM   #3
Fropleyqk
Nom Nom Nom
Fropleyqk's Avatar
Wow, that really does look a lot better. I havent seen anyone use the roller method yet. Good job.
Fropleyqk is offline   Reply With Quote
Old 05-04-2007, 10:20 AM   #4
Big Tool
Looks great. After i had mine done i was thinking about having the entire body sprayed with it. Never have to worry about scratches or road chips
Big Tool is offline   Reply With Quote
Old 05-04-2007, 10:37 AM   #5
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I have done the roller method and paint brush method a few times, holds up nice as long as the prep is good.
http://www.certifiablejeep.com/images/thirdproject/116_1643.jpg
http://www.certifiablejeep.com/images/thirdproject/116_1644.jpg
http://www.certifiablejeep.com/images/thirdproject/116_1657.jpg
http://www.certifiablejeep.com/images/thirdproject/122_2222.jpg
http://www.certifiablejeep.com/images/thirdproject/122_2225.jpg
cb
CertifiableJeep website
'76 ORANGE CJ-5
'76 MAROON CJ-5
'78 SILVER CJ-7
'82 WHITE CJ-8
ORANGE JEEP CLUB #41
certifiablejeep is offline   Reply With Quote
Old 05-04-2007, 10:38 AM   #6
certifiablejeep
Bicentennial Nickel
1976 CJ5
Found the link to the Orange one as well...
http://www.certifiablejeep.com/herculiner.php
cb
'76 ORANGE CJ-5
'76 MAROON CJ-5
'78 SILVER CJ-7
'82 WHITE CJ-8
Old 05-04-2007, 10:39 AM   #7
certifiablejeep
Bicentennial Nickel
1976 CJ5
Most import part of his roller picture... WEAR GLOVES! that stuff doesn't come off for like a month...
cb
'76 ORANGE CJ-5
'76 MAROON CJ-5
'78 SILVER CJ-7
'82 WHITE CJ-8
Old 05-04-2007, 10:52 AM   #8
dirtman13
2007 CJ7
I rolled mine on also and it has held up very well. Herculiner also make a UV protectant that I would recommend.
http://www.herculiner.com/topcoat.html
dirtman13 is offline   Reply With Quote
Old 05-04-2007, 12:17 PM   #9
green cj 78
1978 CJ7
I think the most important thing is to just prep it really well, and think everything out and take your time. I do have a little experience with Herculiner before. Masking is really key, and remove the tape when its still tacky. Today, I'm gonna look for some shiny bolts for the shifter plate. Some contrast will look nice. Soon I want to get a stainless dash with aluminum and chrome accents.
Also, fitment is going to be an issue if I ever want to put another hard top on, so I left the rail bare, and I will go over it with a duraliner spray can. Its still durable, but a lot thinner and smooth.
78 CJ7
97 XJ 2wd POS.
Old 05-04-2007, 12:44 PM   #10
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
That does look good! I just did mine about a month ago or so. I've done it with the roller setup before but this time I used a spray gun. I just bought a HF Texture Spray gun for like $25 and "spattered" it in. Took all of about 10 minutes per coat and I sprayed 3-4 good coats. Thought I'd toss that out there for those of you with compressors.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 05-04-2007, 12:55 PM   #11
elks96
So if I have a tub in really good shape. How far do I need to take the prep. I have a few spots with light rust, that I can get back to bare metal. Do I need to take all the old paint off all the way down to bare shiny metal? Or if I hit hard and rough the surface will it be ok? Of course I will remove all the dust, dirt, rust etc. Plus all the rust. The roller method seems really nice.
Thanks for the help.
elks96 is offline   Reply With Quote
Old 05-04-2007, 01:02 PM   #12
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You can lay it over sound paint. Just thoroughly scuff everything, wash it out with a good degreaser (like superclean), let it dry, wipe down twice with Xylene and go for it.
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Old 05-04-2007, 01:10 PM   #13
bdmonist
WTF is that?
bdmonist's Avatar
Besrk - Do you have pics of the spray in? Is there a texture difference once complete compared to the roll on? Is that texture spray gun similar to an under coat gun? Thanks!
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
AMC 20 Write Up
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline   Reply With Quote
Old 05-04-2007, 01:11 PM   #14
blurred
Junior Member
blurred's Avatar
1978 CJ7
Few questions:
1)how long did it take, prep, paint, everything?
2)how much did you get?
3)is it really rough when put on? read things about being rough on the knuckles, etc.
4)does it affect doors closing, tops, any other fittings on the jeep?
5)what did you plug bolt holes with, and did you just leave the drain holes uncovered?
blurred is offline   Reply With Quote
Old 05-04-2007, 01:18 PM   #15
dirtman13
2007 CJ7
Originally Posted by blurred
Few questions:
For me
About half a day
1 Gallon + 1 bottle UV Protectant
I try not to drag my knuckles when I drive
Tape mine off. Have no problem
Painted over the drain holes then cleaned out hole after it dried. Waded up tape in threaded holes.
Glock Forum
