Herculined complete jeep - JeepForum.com
post #1 of 9 Old 01-02-2010, 10:14 PM Thread Starter
dariopop
1980 CJ7
Has anybody ever done or concidered Herculining an outside of a jeep,and never having to worry about scratching it ever again while off-roading, I saw a jeep hood that was done and it sure looked good,sure would be an easy touch-up if it did get scratched up whiile out in the woods.
Any veiws on this?
Thanks
CJ
dariopop is offline
post #2 of 9 Old 01-02-2010, 10:22 PM
kw89425
i have been thinking about it you can do it in colors
kw89425 is offline
post #3 of 9 Old 01-02-2010, 10:24 PM
Bane7962
guy i talked to about it basically sanded his paint off then did the whole thing, minus the plastics and the taillights.
im gonna do it once my paint gets so ****ty i cant deal with it anymore.
Bane7962 is offline
post #4 of 9 Old 01-02-2010, 10:24 PM
JeepnBlake
There was a guy on here who bought a jeep like that and actually stripped all that stuff off.
Cheap paint is what i do.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #5 of 9 Old 01-03-2010, 06:57 AM
JavaTee
1979 CJ5
I used Durabak (it already has UV block in the paint & comes in mulitple colors), with KBS coatings as a base after I wire wheeled the entire tub. Here's a couple of links, Cote-L Distribution Company Chassis Paint Kit - KBS All-In-One Chassis Kit - KBS Coatings
So far it's held up very well, two years plus. My CJ is a sun sitting/all weather, travel baby. It's been from the mountains (two weeks ago) through the salt spray from the roads, to the beach and the salt air.....so far so good.
I would recommend Durabak & KBS coatings to anyone.
Later, T.J.
'79 CJ5 258 w/MC 2100 & Team Rushed, NP435/Dana300 <--twin sticked, NT Dana 44 (w/Aussie) rear, and NT Dana 44. 3" susp lift, Currie shackles, 1" body Lift, Durabaked tub inside & out.
Military members (current or completed service) check out
JavaTee is offline
post #6 of 9 Old 01-03-2010, 07:38 AM
Boodie
1961 CJ5
Durabak and Herculiner both fade. No matter how much it says it has UV Blocker. I'm sure most of you know this just by looking at the inside of your tub (for those of you who have used it). I have used both, and a little Tire Foam brightens it right up! You might get some crazy looks at your local car wash standing there spraying your entire Jeep with Tire Foam, but it does work! LOL!
Just my 2 cents!
1961 Willys CJ-5
258 I6/4 Inch Suspension Lift/3 Inch Body Lift/2 Inch Shackle Lift/34" Tires
Boodie is offline
post #7 of 9 Old 01-03-2010, 09:11 AM
kp900
Was up north this summer. Ran into a guy who did the inside black and the outside. Looked OK seems to hold the dirt on the outside, hard to clean? but if its always muddy does it matter?
kp900 is offline
post #8 of 9 Old 01-03-2010, 11:40 AM
nitor
I used to spray bed liners. Used SEM bed liner. It can be made to match any color by adding paint to the tintable. I thought about spraying the outside of a CJ7 I had at the time. I never got around to it. I did spray several Jeep interiors. It looks good and hold up well. The interiors I sprayed were all black. I'll probably spray my interior someday.
Thanks,
Jim
nitor is offline
post #9 of 9 Old 01-03-2010, 01:11 PM
poppatello
I have thought about it too. I know a guy who owns a Line-X company and he said 900 to paint my jeep for me any color. He can even mix in metallic! He said he did one jeep like that and it came out sweet. I would think that it would be easy to clean if you use a pressure washer. However, I did the inside of my jeep and would never do it again. Not the easiest to clean. Water doesn't run out so the puddles turn to water stains once it does dry up. I like the Camo look on the jeep above. I have seen trucks with black and flat green. The all flat green I thought looked great. I'm planning on doing an orange color with a little blue or gray metallic. The biggest down fall is prep. Takes a lot of time if you want it to turn out good. If you pay someone like I will it can cost you which is why I plan to prep my own.
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
thoughts on a CJ that is entirely herculined psbeaman Jeep CJ Forum 10 07-07-2009 12:00 AM
Herculined hardtops? LostINohiO Jeep CJ Forum 10 11-28-2008 05:14 PM
Herculined inside of my cj7 mmerlina Jeep CJ Forum 14 01-30-2008 11:01 PM
Herculined the tub today...I got pix green cj 78 Jeep CJ Forum 29 05-06-2007 03:42 PM
304 Rebuild... almost complete certifiablejeep Jeep CJ Forum 17 02-21-2006 06:17 PM
