HELP!!!!! Trans failure - Page 2 - JeepForum.com
post #16 of 34 Old 12-01-2013, 07:57 PM Thread Starter
goochieman83
2014 JK Wrangler
The switch for the Quadratrac that is in the glovebox is just there, nothing is hooked up. I honestly don't know a ton about the Quadratrac system.
goochieman83 is offline
post #17 of 34 Old 12-01-2013, 10:08 PM
lucdog
lucdog's Avatar
1980 CJ5
This is a good place to start.
.http://jubileejeeps.org/quadratrac/index.htm
The transfer case is the same, be it a truck or a CJ .
You should be able to ID if you have the low range unit on yours , from checking the link out.
So, if in fact you do have a low range unit, I wonder if you may have Inadvertently moved the lever to neutral.
There are 3 positions , low range, neutral, and high range, neutral being in the middle.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #18 of 34 Old 12-02-2013, 07:19 AM Thread Starter
goochieman83
2014 JK Wrangler
Transfer case is in 2H, just to make sure I put the t-case in every position and shifted through the gears. Still nothing. Have some finals today then will be able to drop the pan again. I'm hoping it is just I forgot to put the o-ring on the pickup tube. I'll keep ya posted.
post #19 of 34 Old 12-02-2013, 09:28 AM
lucdog
lucdog's Avatar
1980 CJ5
There isn't a "2hi" on a Quadratrac transfer case, its just HI ,LOW , or NEUTRAL. The Q-trac is full time 4wd, unless a mile marker part time kit is installed.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #20 of 34 Old 12-02-2013, 12:00 PM
Centerfire
Centerfire is offline
post #21 of 34 Old 12-02-2013, 02:47 PM
JeepHammer
Running On Empty...
1973 CJ5
I hope it's just sucking air, getting a TH-400 rebuilt is a hit in anyone's wallet...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #22 of 34 Old 12-03-2013, 06:07 AM Thread Starter
goochieman83
2014 JK Wrangler
Now I'm really confused. The t-case has four gears from dash back. But it has Quadratrac as well, although it's not hooked up to anything. So if it is supposed to only have Hi, Low, and Neutral why would mine have 4 gears? And there is no panel to tell, that was probably gone years ago. Still have yet to get under the thing to see what I fudged up.
post #23 of 34 Old 12-03-2013, 08:31 AM
lucdog
lucdog's Avatar
1980 CJ5
While your under the Jeep, take some pictures of the transfer case, and the shift levers inside the tub.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #24 of 34 Old 12-03-2013, 03:21 PM Thread Starter
goochieman83
2014 JK Wrangler
http://m.oreillyauto.com/mt/www.orei...3230&ppt=C0023
Working on getting the pictures up but here is the filter I installed, and I do have a shallow pan.
post #25 of 34 Old 12-05-2013, 06:13 PM Thread Starter
goochieman83
2014 JK Wrangler
Still no chance to get the pan off, between work, finals, and freezing rain no time. Will keep you all posted though.
post #26 of 34 Old 12-18-2013, 02:55 PM Thread Starter
goochieman83
2014 JK Wrangler
Alright, I'm back. So I finally took the pan back off. The pickup tube wasn't all the way in the trans and there was no o-ring on the tube. I instaled a new o-ring and seated it all the way in the transmission and installed the filter and pan. Started it up and put it in gear and nothing. Put it in reverse and it moved about a foot, put it back in drive and with some revs it moved forward a little then stopped. I'm officially lost. Any ideas?
post #27 of 34 Old 12-18-2013, 03:57 PM
Centerfire
Is the motor running, and in neutral when you check the fluid level?
Is the vehicle on level ground when checking the fluid level?
post #28 of 34 Old 12-18-2013, 04:02 PM
Gratefulcaver
1983 CJ7
Vacuum Modulator hooked up ?
Just an idea ...
Gratefulcaver is offline
post #29 of 34 Old 12-18-2013, 04:35 PM
skizriz
1978 CJ7
Do this, and listen to Bill. I know where he is leading, and if he is correct, you may be doing damage to your transfer case.
Do you by chance have locking hubs on the front axle?
skizriz is offline
post #30 of 34 Old 12-18-2013, 04:53 PM
lucdog
lucdog's Avatar
1980 CJ5
The transmission should be in park when checking fluid level.
What's the fluid level at?
Your description sounds like low fluid.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
