Help with Rush Upgrade and/or ignition problems?
#46 | |
96171 Autolite Ignition IGNITION WIRE SET AUTLT $28.88
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=ATL&MfrPartNumber=96171 This is what I used from Advanced... Has the correct wire for the 2F cannister coil.
__________________ - 1982 CJ5 - AMC 258 TeamRushed, MC2100, T-176, Dana 300, Goodyear AT 31's, AMC AM Radio, SuperTop, Tuffy Stereo Console , Black Diamond AT Shocks , CJ Draw Bar, Herculiner The secret to a jeep, especially a cj, is you can't panic. - Mike |
#47 |
Okay, I found some 8mm silicone plug wires at Carquest, that are made by Prestolite for $40. Don't laugh. Think they're any good. I'm just not finding crap locally.
Terry ~ USN Ret. 30Sep07 : ) 1982 CJ7 4.2L ~ T-999 ~ Dana 300 ~ SOA Conversion Dana 30/AMC 20 with Truetrac - one piece axle - 4.10's 33" Toyo M/T's on Pro Comp Xtreme Series 1069 Borla header and Catback Exhaust System Jeeperman bumper w/ Ramsey Patriot 8000 - Jeeperman tire carrier/bumper |
#48 |
Team Rush for 77 cj
to Jeephammer,
Next door neighbor just bought a 77 cj / 258 & prestolite ign. runs very bad. He has asked me to help him w/ the tune-up etc. Got the Motorcraft 2100 carb built & wanting to upgrade the ign. Anything different about the 77 that I need to know, or will I be able to install the 78 + dura-spark w/ wiring upgrades or what would you reccommend ? thanks |
#49 | |
What was I thinking
You should be able to install a Duraspark distributor and ICM with little problems if your comfortable with modifing your wiring. I installed a distributor of an 84 CJ into my 76 and added the ignition harness out of my 79 CJ to make it work. I would of installed the 79 distributor but the plats had a lot of slop inside. Not sure what was missing in that distributor. |
#50 |
Thanks
Wiring will be no problem. |
#51 | ||||||||||
Running On Empty...
Hello.
------------------------- Quote:
DO NOT GROUND THE 'GREEN' SIDE OF THE COIL OR YOU WILL SMOKE THE COIL WHEN POWER IS APPLIED! That extra green wire is for your aftermarket tach, or other accessory. If you don't need it, clip the wire off or tape it over! ------------------------------ Quote:
OR a dedicated GROUND wire to the engine cylinder HEAD(S). YOU DO NOT GROUND THE COIL CONNECTIONS! ------------------------------------- Quote:
We've covered this may times... There is a 'Quirk' in the DuraSpark ignition module used in Jeeps from '78 to '90, and you CAN NOT leave the key switch on when the engine isn't running or you will overheat both module and coil! Quote:
------------------------------------------ Quote:
Very common when you overheat it by dead grounding its feed to the ignition coil... ------------------------------------- Quote:
0.45" is nearly half an inch! --------------------------------------- Quote:
Plug wire or coil wire not pushed in all the way, Rotor not seated on the shaft correctly, Cheap parts that are actually rubbing on each other, Something like that. ------------------------------------- Quote:
In just a few minutes! When you grounded the green wire, then turn the ignition switch on, you were dead grounding the coil with full current going through it. It's a wonder it didn't make 'Magic Smoke'... You can also kill your coil over time if you engine head (Spark Plugs) don't get a proper ground, so run a dedicated ground wire to your cylinder head! Quote:
Some accessories, like some tachs and engine diagnostic machines, or fuel injection computers will need a coil negative source, but for what you are doing, you don't need it. Quote:
Take the cap/adapter off, make sure the adapter is properly seated, Make sure the rotor is properly installed, look for signs of rubbing or contact inside the cap or on the rotor nose. You will get a 'Popping' sound if the rotor center terminal doesn't make full contact with the center electrode in the cap, so make sure the center 'Spring' isn't pushed down on the rotor, Check each and every one of the plug wires, makes sure they seated on the terminals correctly... On both the coil and the distributor cap... Since it's an I-6, check the plug wire to plug connections also. Oh and its an 83 CJ7, 258 with a Weber 34/34. Sorry for the forever long rant, but I really hope this upgrade will help my Jeep. Im sure I'm missing something. [/QUOTE]Just a suggestion, but break up your thoughts a little more, when you guys run everything together, it makes it hard to read for me!
REMEMBER, 'Free' internet information is worth EXACTLY what you paid for it! LINK:Dual Battery Diagrams & Explanations. LINK:Winch, Welding, 'Lend Power' Project, LINK:Water Proofing Ignition, Hubs, Ect., LINK:BSERK's Winch Plate, LINK:AMC V-8 Front Cover Recondition, LINK:How An Ignition Works, LINK:Ignition Swaps '77 Older Jeeps, LINK:'78-'90 Jeep Ignition Upgrades, |
#52 | |
Running On Empty...
'74 to '77 had PRESTOLITE. NO UPGRADES FOR PRESTOLITE. I would use a 'Junk Yard' HEI with a gear change If I were doing it, OR, I'd switch over to the distributor from '79 Jeep with 258 I-6 Engine and use HEI style module to trigger factory coil.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
