Help with roll bar!! - JeepForum.com
post #1 of 4 Old 06-05-2014, 06:36 PM Thread Starter
Bojon
1981 CJ5
I need help deciding what I'm going to do with my roll bar. The front feet are basically rusted out, and I was planning on cutting them off and replacing them. But the rust is worse than I thought and goes a little way up the tube.
I haven't had any luck locating a bar out of the junk yard. They are either smashed or its a fender mounted bar. Not looking to build a custom cage, not yet at least, I want to focus on getting the Jeep back together.
Can I replace the lower section of the bar, maybe using an inner sleeve? If so any ideas on how I could form the bend above the feet.
Any ideas at all, I'm all ears.
Jered
Bojon is offline
post #2 of 4 Old 06-05-2014, 08:08 PM
RenoF250
I would find a Wrangler bar and replace it. I have a pretty good CJ roll bar but shipping would kill you. I am going to be in Silverton first week of August if you can wait that long and want to drive out there.
RenoF250 is offline
post #3 of 4 Old 06-05-2014, 08:48 PM
only in a jeep cj
Post up on your local Craigslist that your needing a later CJ5 roll bar.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 4 Old 06-05-2014, 09:24 PM Thread Starter
Bojon
1981 CJ5
Good call, just posted an ad on Craigslist.
Reno, the CJ5 roll bar is different from the 7 and the wrangler. I'm sure they can be modified to fit, but then I might as well just fix what I have.
If nothing pops up on craigslist fairly quick, I'm going to try and get a piece of tube off a junkyard bar and use that to repair mine.
Jered
Bojon is offline
