Help with rear crossmember!!!!! - JeepForum.com
post #1 of 5 Old 05-20-2002, 05:04 PM Thread Starter
CJ7Jeff
Post Help with rear crossmember!!!!!
Can somebody help me with some sort of instructions on how I go about removing that crappy rear crossmember so that I can replace it with something better? I am guessing that you have to do something to get the body mounts out but I can't figure it out.
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02.
CJ7Jeff is offline
post #2 of 5 Old 05-21-2002, 06:15 AM
Bulletproofcj7
Post
There are bolts that go through the body mount and may be rusted badly,They may be a pain to remove. As for the cross member, it is welded on and must be cut or chisled off, if its not already rusting off. I used a heavy piece of angle iron and welded it to the frame then another small piece of angle iron welded to the inside bottomn of the new cross member to form a channel for the gas tank mount.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #3 of 5 Old 05-21-2002, 08:01 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Thumbs up
Exactly what he said! I did the same thing! <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
post #4 of 5 Old 05-21-2002, 05:42 PM Thread Starter
CJ7Jeff
Post
Thanks, I was going to do the same thing with a piece of channel. I had a hard time finding all of the body mounts above gas tank because it is an oversize tank. Got those out and the rest of them and now I just have to get that dang rusted piece out of there! Thanks again!
CJ7Jeff is offline
post #5 of 5 Old 05-22-2002, 03:03 PM
CJ7Binger
Post
You could just sit in the garage and nag at your roomate since it is his Jeep anyway. Yank the tank. Get out the torch and have some fun. Then send him to the local steel supply where he gets a 49"long piece of 3/16 flat. While he's there they break it over for him into an exact replica of the rear crossmember only beefier. New crossmember price = $20 Thanks for the help Jeff.
83 CJ7(Freaky Green) Chevy383, NV4500,Locked-D44s, and many other goodies, Always looking for other peoples $.02, I can spend that on my Jeep too.
CJ7Binger is offline
New Rear Crossmember twokids Jeep CJ Forum 12 04-15-2009 07:54 AM
Rear crossmember ? NWA_CJ7 Jeep CJ Forum 10 03-03-2008 06:37 PM
Rear Crossmember tsujeeper Jeep CJ Forum 15 01-15-2008 10:44 PM
Rear Crossmember 84MSRB Jeep CJ Forum 9 12-30-2006 03:05 PM
Help with Rear Crossmember 2000XPSD Jeep CJ Forum 1 09-19-2005 12:43 PM
