Help, put jeep back togeather , tail lights and blinkers don't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Help, put jeep back togeather , tail lights and blinkers don't work
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 05-09-2012, 08:30 PM   #1
home_alone1
1983 CJ7
Im putting my jeep togeather and I tested the head lights and they work and the small left blinker works , right blinkers, large front left blinker , brake lights don't work , it was raining today and might have gotten wet ? The large left blinker and large right blinker were pluged in and the small left blinker went out while the other two lights were to dim to really see. Maby not producing enough amps? Please help
Are you sure?......
No.
home_alone1 is offline   Reply With Quote Quick reply to this message
Unread 05-09-2012, 08:42 PM   #2
brian613
1977 CJ5
check the bulbs and grounds
77 cj5 304 v8 np435 twin sticked dana 20 transfer scout dana 44's with 4.88 gears
project roadkill
brian613 is offline   Reply With Quote Quick reply to this message
Unread 05-10-2012, 07:16 AM   #3
twoleos617
the front blinkers ground themselves to the body via the special bolt they use. make sure everything has clean contacts with the body and wireing harness plugs are not corroded. a little sand paper on the contacts to clean, followed with dielectric grease works wonders on all you plugs!!!!!!!
the rears as well ground to the body so make sure the body and mounting bolts are making good CLEAN contact. I ran short ground wires for the rears on mine and got a better contact and brighter lights. this helped a ton as i have painted corner gaurds on the rear.
they're all looped together so pull everything, clean, and reinstall everything completely before rechecking.
check with the engine off and running. sometimes a weak battery will give funny results when just in the ACC possition but work well with the engine running.
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline   Reply With Quote Quick reply to this message
Unread 05-10-2012, 09:45 AM   #4
turbogus
1978 CJ5
Location: Albany~town, Oregon, Oregon my home and for 200 billion slugs
While you're at it you might consider doing this too; http://www.jeepforum.com/forum/f8/si...grade-1022601/
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline   Reply With Quote Quick reply to this message
Unread 05-10-2012, 08:29 PM   #5
home_alone1
1983 CJ7
Thanks for the input gents , I ended up cleaning all the connections and checking the grounds, the tail lights wernt grounding to the jeep, I removed the paint in the holes where the bolts go and wala all lights worked again. Thanks again
Are you sure?......
No.
Unread 05-11-2012, 10:55 AM   #6
turbogus
1978 CJ5
That's great news home alone, I reckon that why service manuals always start with the simplest and easy things when doing a diagnostic. I've found over the years even without a manual going for the fueses first, then the grounds, then the .... etc.
