Help! Power steering line leaks - JeepForum.com
post #1 of 14 Old 02-10-2013, 01:34 PM Thread Starter
79CJ7dude
1979 CJ7
Just did the H1 hummer steering box upgrade, and the power steering lines that thread into the steering box are leaking in-between the nut and the line. I've tried Teflon tape on the threads and tightening it down really tight. So I don't know if it doesn't have a good seal between the flare and the nut or what, but I'm getting quite frustrated with it. So any advice would be greatly appreciated. Thanks!
79CJ7dude is offline
post #2 of 14 Old 02-10-2013, 04:20 PM
lucdog
lucdog's Avatar
1980 CJ5
There are 2 different types of lines used on CJ's. '76 thru 79 or 80 IIRC used a flare on the fittings. From there up to '86 they used a o-ring type. Not sure on this, I'm guessing the H1 box uses the Oring ( I haven't seen one)
What fittings do you have on your Jeep?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 14 Old 02-10-2013, 06:24 PM Thread Starter
79CJ7dude
1979 CJ7
Mine has the flare and nut.
post #4 of 14 Old 02-10-2013, 07:37 PM
CSP
Any '80 and up box uses metric o-ring fittings. That's the problem. Hopefully you didn't damage the threads on the box threading SAE lines into them.
CSP is offline
post #5 of 14 Old 02-10-2013, 07:42 PM Thread Starter
79CJ7dude
1979 CJ7
They threaded in fine, they just leak in-between the line and the nut.
post #6 of 14 Old 02-11-2013, 08:45 AM
CSP
They may have threaded in ok, but they aren't the right part for the job. That's why you have a leak. You can either have a custom pressure hose with metric o-rings at the box end and SAE inverted flare at the pump, or just swap out the fittings on the pump to metric oring and stick with a standard o-ring hose for any '80 and up CJ.
CSP is offline
post #7 of 14 Old 02-11-2013, 09:01 AM
82JeepCJ7
1982 CJ7
Just go down to the parts store and get a set of power steering lines for a 80 and up CJ7. They will have the correct ends.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 14 Old 02-11-2013, 09:15 AM
CSP
At the pump end they won't be correct.
CSP is offline
post #9 of 14 Old 02-11-2013, 09:28 AM
82JeepCJ7
1982 CJ7
The pump end will match the style of fitting on the steering gear. They don't make a hose with a flair end on one and o-ring on the other. I just purchased a new set for mine. My Jeep also has a H1 box on it. The lines bolted up perfectly.
post #10 of 14 Old 02-11-2013, 10:27 AM
lucdog
lucdog's Avatar
1980 CJ5
Yours is a 1982, the OP's is a '79. His pump has the flared fitting.
OP, do what CSP said, swap the fitting on your pump to the o-ring style, and get a new Oring style line.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #11 of 14 Old 02-11-2013, 12:31 PM
248107
Guest
1983 CJ7
Guess the pump don't come with new lines.What does the retailer say about the hoses.CSP is correct to my knowledge.My 83 hoses won't thread into a 78 i know.
248107 is offline
post #12 of 14 Old 02-11-2013, 02:57 PM
82JeepCJ7
1982 CJ7
Yea, I forgot about the age of his pump. The easiest way is to change the pressure union to the newer style. I know a new pump is not that much either, so you may be better off just replacing the pump with a new one.
post #13 of 14 Old 02-11-2013, 06:11 PM
timgr
1975 CJ6
Reiterating what's been described (in dribs and drabs) above -
IIRC the GM pump just has an added fitting to use the o-ring connection. You can get one from a steering pump at the pick-a-part. Then use the o-ring style hoses ('80 up?) that now match the gear and the pump.
Or, have your local hydraulic shop make a replacement hose with o-ring fittings on the gear end, and a flare nut on the high-pressure pump end.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #14 of 14 Old 02-12-2013, 10:47 AM Thread Starter
79CJ7dude
1979 CJ7
Thanks guys for the advice! I'll go down a hydraulic shop some time this week and have them ether make me some new lines, or weld a fitting on my old lines.
