Help please!!! - JeepForum.com
post #1 of 10 Old 11-22-2002, 02:54 PM Thread Starter
merch_boy
Help please!!!
I have a 83 CJ7. It sat for about a year while I saved money to get tranny fixed. Ran it for a few weeks no problems. Now, it stalls on me. I can drive it for a few mins, then when I pull up to a stop sign it dies. Or it will just jerk really hard. Have no clue what this could be. Thanks!!
p.s. I have replaced the fuel pump, and fuel filter.
merch_boy is offline
post #2 of 10 Old 11-22-2002, 11:05 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Might try rebuilding the carb. Its possable that after sitting for so long ugly things could have crawled in there and are now wedged in the various fuel delivery circuits.
jeepdaddy2000 is offline
post #3 of 10 Old 11-23-2002, 06:15 AM Thread Starter
merch_boy
I have ben thinking about that. Thanks. I wil order the kit today.
post #4 of 10 Old 11-23-2002, 08:42 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
When you pull the carb apart, see if it is really dirty or has any bits of rust in it. Water or other junk might have got into the tank with it sitting for a year (especially if it was outside). You might have enough crud or rust in the tank now to keep plugging up filters. Good luck.
BESRK is offline
post #5 of 10 Old 12-11-2002, 12:04 AM
K5QM
YOU MIGHT TRY A CAN OF DRY GAS OR A PINT OF ALCOHOL IN THE TANK BEFORE DISASSEMBLY. JEEPS ARE PRONE TO COLLECT MOISTURE IN THE TANKS THAT SET FOR A YEAR OR SO.
JERRY
k5qm@arrl.net
K5QM is offline
post #6 of 10 Old 12-11-2002, 06:56 PM
werewolf7111
before spending money "guessing" look at the fuel and ignition system ( i agree- its probably carb related but when its money- its better to measure twice and cut once)
Joe MSME PE
werewolf7111 is offline
post #7 of 10 Old 12-11-2002, 10:58 PM
Crash&Burn
I'd put 3 or 4 jugs of HEET in it and drive it some, before I try anything else.......
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #8 of 10 Old 12-13-2002, 02:31 PM
livin2learn
livin2learn's Avatar
I would take the Carter BBD off and hit it with a big hammer....then throw it in the trash.
After that I would go and buy a Weber or a Motorcraft 2100.
Whichever suits your budget
Odds are the problem is your Carter. You can rebuild it, but take notes, because you'll be doing it again in 3 to 6 months.
Seriously though, you should start saving for a new carb. After I put a Weber on mine, it has been runnin gbetter than ever. Well worth the $300.
Good luck.
, I6-258, T-4, 1" M.O.R.E. BL, RE 2.5", Weber Carb, 33" ProComp MT
livin2learn is offline
post #9 of 10 Old 12-13-2002, 04:53 PM
MR.CJ-7
I'll second that motorcraft 2100. Can't say enough good about it. Never gives me any crap when rockcrawling.
Former CJ'er
MR.CJ-7 is offline
post #10 of 10 Old 12-13-2002, 09:56 PM
rustyCJ
Re: Help please!!!
auto or manual tranny? manual or power brakes? when you first start it does it idle good, after its warmed up how does it idle? what do you mean jerk really hard, jerk and then die like killing it with the clutch? granted the carter needs a lot of attention to keep it running but its hard to blame it for every problem with the way a jeep runs. this is a jeep that sat for a year then had a fixed? tranny. it could be a lot of things.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
