that number does not match the I.S. NOtes for the 85 /86 CJ MR252 manual. Is it located on the shortest leaf in the center on one side....comming out from under the spring plate?
Yes it is located in the area you discribed.
Although not sure if it came out from under the spring plate didnt notice it the first time I had it part, took the spring packs off today trying to figure out why they look to be leaning outward at the rear.
If they are stock there is no lift, just different spring rates.
Rear/6 cyl/soft top
Standard 3332
Soft Ride 3935
Heavy Duty 4386
Rear/6 cyl/hard top
Standard 3331
Soft Ride 3935
Heavy Duty 3855
Front/6cyl/soft top & hard top
Standard 3229
Soft Ride 3933
Heavy Duty 3850
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
