#1 | |
Help with Nutter bypass
Well I printed all the info on the nutter bypass and followed the purple and orange from the distributer to the firewall.
The instructions say by the coolant recovery bottle is the ignition module I cannot find it on my 83 CJ7 but it is a POS. I did find a box above the heater box on the passenger side that looks like it. I also found a blue?/black? box at the driver toe kick but I think it may be the cruse control. Any help is appreciated Thank in advance Craig
#2 |
Its a "ribbed" silver box bith a gangload of wires coming out. I has a 79 and it was placed (by someone) on the fender higher up on the driver side.
Other than that, my 80 cj7 has an HEI (?) and the ignition is attached to the top of the distributor: ![]()
Andy _______________ 1980 CJ-7 : 151GM : Stock : In process of restoration (always constant, and something to do.) Project "Vote Utilitarian" |
#3 |
wat is a nutter bypass???
#4 |
Google "Nutter Bypass" and you can read all day if you want to.
"I don't do things, I give advice." by an old geezer in the movie "Milagro Beanfield War" "After all, it is the slave who thinks himself a free man who makes the best slave." (Unknown) “A closed mind is like a closed book; just a block of wood”. Chinese Proverb |
#5 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The ignition module is on the driver's side inside fender 'Waaaayyyy' down low under the washer bottle. I also set the carb different and mine pass emissions. I set the stepper pins in the center of their travel like they were when the computer was running it. This keeps the high speed mix right. All the rest of the directions are good.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
