Help.. No tailights, signals, fuel gauge, - JeepForum.com
post #1 of 10 Old 04-25-2013, 03:14 PM Thread Starter
wml001
1979 CJ7
I have a 1979 Cj7, the lights in the rear arent functioning, they bulbs are new, the housing etc is all new. The CJ, runs fine all electrical in engine bay is fine, I have a 302 in it, but nothing electrical beyond firewall working. Anyone have any ideas?
wml001 is offline
post #2 of 10 Old 04-26-2013, 02:43 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Dash light work?
Brake lights work? Turn signal Work?
need mo info..
John Strenk is offline
post #3 of 10 Old 04-26-2013, 08:35 AM
texasdave
texasdave's Avatar
1980 CJ7
Bad grounds. Where is last place in the circuit do you have voltage?
texasdave is offline
post #4 of 10 Old 04-26-2013, 09:27 PM Thread Starter
wml001
1979 CJ7
No ligts in the dash are on, and I have no accesories. No turn signals, hazard works only in rear driverside light, running light/license plate light work when the right blinker is switched on. I tried running a ground directly from the batter to the only ground I could find from this harness, still nothing at the passenger side. The tailights are newer style, the type that ground within the unit, however there is a ground at the end of the wiring harness on the passenger side, I removed cleaned and sanded the ground still nothing. Also
wml001 is offline
post #5 of 10 Old 04-27-2013, 02:22 AM
John Strenk
1976 CJ5
I think the ground you found is only for the marker light. It wouldn't help you for the ground you probably need. There are no ground in the OEM harness. And all your troubles do sound like a grounding problem. Almost sounds as if the battery (-) is not grounded to the tub. If it's a steel tub then a wire from the battery to the tub is needed and if it's fiber glass then you will have to find the common grounding point and make sure it's connected to the to the battery.
Do you have a steel or fiberglass tub?
post #6 of 10 Old 04-27-2013, 10:51 AM Thread Starter
wml001
1979 CJ7
I have a steel tub, I just find it odd, because the front headlights work, everything within the engine compartment works, and the windshield wipers randomly started working. I will follow the ground from the battery and see where it goes, and let you know. Thanks
wml001 is offline
post #7 of 10 Old 04-27-2013, 10:54 AM Thread Starter
wml001
1979 CJ7
The ground from the battery, goes directly to the top of the engine manifold. Update, I now have turn signals in the rear, I re-wired everything back there, still not locating any sort of ground
wml001 is offline
post #8 of 10 Old 04-27-2013, 02:15 PM
Stormpaw
1983 CJ7
I would highly recommend checking out Jeephammer's post on dedicated grounds.
Basically, AMC was cheap and didn't install any dedicated grounds. Instead, they grounded everything to the body or chassis. However, steel isn't a great conductor to begin with. Add paint, rubber body mounts, and 35 years of corrosion and you are bound to have some electrical problems. Running a couple ground wires is pretty simple and, I am guessing, will probably eliminate the problems you are having.
I hope that helps.
Stormpaw is offline
post #9 of 10 Old 04-27-2013, 02:27 PM Thread Starter
wml001
1979 CJ7
I took a look at it, I agree that there is something not grounding out properly.. I have break lights, turn signals and hazards now, still no running lights. I'm running out of ideas.
wml001 is offline
post #10 of 10 Old 04-27-2013, 06:11 PM
jimdubose
1978 CJ5
do you have one of these?
http://www.offroaders.com/tech/Jeep-...grams-1978.htm
come in handy in situations as the one you describe
jimdubose is offline
