Help! New Used CJ Hard Doors - JeepForum.com
post #1 of 2 Old 06-16-2003, 04:47 PM Thread Starter
brownrecluse
Just got some Hard doors for my CJ. I'm having some trouble getting them on believe it or not. I just put on new windshield hinges and the botttom door brackets on the body as well. It seems that it too tight of a fit for the door pegs to fit, and there is a weld on the hinges so I cant "pry" it open more.
Any ideas? Is this a common problem?
Thanks,
Jeff
brownrecluse is offline
post #2 of 2 Old 06-16-2003, 09:47 PM
only in a jeep cj
The only two things that come to mind are: Maybe the new hinges are aftermarket and don't have the same size pin to match the older hinges.
The hinges are not in line/have matching angles and they are getting into a bind when you try to lower the door down. To install a different set of doors on a Jeep, the door must be set to the body, the stricker post set up to match the door, the windshield slope then set to the doorframe, and if needed, then the hard top to fit......all using the "floating" nuts behind the adjustable hinges in the doors and lower mount.
Can you measure the shaft vs the hole and see if there is indeed a big difference as there should be no need for "prying".
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
71 cj5 hard top and doors siddhartha37 Jeep CJ Forum 15 03-24-2011 12:13 AM
ny one looking for some hard doors? bjf498 Jeep CJ Forum 0 05-11-2008 11:45 AM
Cj-7 doors revisited-hard doors the answer? newjeepowner Jeep CJ Forum 2 11-12-2007 07:27 AM
Wil 81 Cj7 hard doors fit an 86? TexasCJ7 Jeep CJ Forum 1 03-08-2007 01:04 PM
Two Piece Soft Doors VS. Lower hard doors with soft upper halves JeepScrambler Jeep CJ Forum 6 10-27-2005 06:29 AM
