Help needed for a 258 distributor on tester. - Page 2 - JeepForum.com
post #16 of 27 Old 07-13-2013, 06:30 AM
86cj74.2L
86cj74.2L's Avatar
Taking .025 off the block or head of my Saturn would have netted me 10:1 CR.
86cj74.2L is online now
post #17 of 27 Old 07-13-2013, 08:35 AM
swatson454
1983 CJ7
Got it. PM sent
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #18 of 27 Old 07-13-2013, 10:05 AM Thread Starter
ninjakid
1987 YJ Wrangler
Felpro head gaskets and just about every other head gasket out there is in the .045 range when installed.
Used original is 0.25 thick.
My new pistons and just about every other 258 piston in the sub 300 category is .010-20 shorter.
Mine seem to be .015.
I have to redo everything and make sure all my calcuations are correct once more but if I slapped the engine together as is my quench would be somewhere in the .070-80 range and dcr somewhere in the high 6 to low 7's range.
Doesn't seem ideal to me.
Originally Posted by swatson454 View Post
Got it. PM sent
Shawn
Thanks for the help.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #19 of 27 Old 07-13-2013, 10:43 AM
swatson454
1983 CJ7
I just got this response.
Originally Posted by bill jones
-I have seen that story---but that machine is alien to anything I have seen.
-all that electronic stuff I know nothing about at all---never seen a machine like that.
-about the only answer I could have supplied was the one about the looseness of the chuck--and someone else answered that nearly word for word what I would have said.
-I have three of the older machines mechanical driven machines---I have removed ALL of the old wiring---and changed the motor drive pulley ratios to speed up the rpm to where I can test to something over 9000 engine rpm.
-then I installed fairly simple all new 12vdc wiring and put the plug wires off to the side on a 5" diameter round cap style receiver that I can adjust the spark gap from 1/8' out to about .900" or so.
-they are totally different concepts of machines.
-the only thing about your friends machine that might be neat is the variable speed motor---if it is capable of spinning the distributor shaft 4500 or so.
-I wouldn't worry much about the first 200 rpm problem.
bill
Shoot
Question: do your new pistons have a quench pad?
post #20 of 27 Old 07-13-2013, 10:56 AM Thread Starter
ninjakid
1987 YJ Wrangler
Tbh I'm not surprised at this point.
This machine is so very different than all the others out there.
I'm lucky to actually find someone else with one even if he insists I gut it and install this expensive log box.
Pistons are identical in shape to the oem pistons minus some slight changes to the rings and being shorter.
ninjakid is offline
post #21 of 27 Old 07-13-2013, 01:29 PM
86cj74.2L
86cj74.2L's Avatar
I think the thicker gaskets are to keep the CR from increasing with a overbore.
If its anything like the saturn's there should be a few different brands of gaskets of varying thickness. If you shop around.
I do wish I would have gone up to 10:1 on the Satty.
post #22 of 27 Old 07-13-2013, 03:10 PM Thread Starter
ninjakid
1987 YJ Wrangler
Felt relatively good enough at first to do some simple calculations.
Difference in both scr and dcr in a calculator between 3.75 and 3.78 in a stock with no other differences 258 is 258.11/4.23/9.17:scr/7.38dcr and .0398 quench stock, 262.26/4.3/9.3:1scf/7.48:1dcr and same quench.
Stock with a .045 head gasket is 8.8:1scr, 7.09:1dcr and 0.598 quench.
30 over is 8.92scr and 7.19dcr and same quench.
I don't think the little increase in cr is gonna make it ping but I can't see the lower cr and bigger quench as anything but detrimental to performance.
At one point mopar performance made a somewhat thin head gasket but they discontinued them a long time ago and I'd rather not rely on a head gasket that would be hard to find a replacement for.
Even the people that stroke 4.0's complain about the head gaskets and how the thinnest made is .041 or so even with a bigger market for 4.0's.
Either the enginetech specs are wrong or my manuals are.
.022-23 difference in height verified between multiple new and old pistons, not .015 which is the difference is when you use info from the manufacture website and oem specs in a couple different calculators.
Which is why I have to double check everything myself which is such a pain with these stupid headaches.
Not sure if I need this oil hole or not.
ninjakid is offline
post #23 of 27 Old 07-13-2013, 04:20 PM
swatson454
1983 CJ7
Ninja,
There is such a little quench pad, I don't know how much it's going to matter. Odds are good it's going to ping at anything much over 9:1 no matter what. I don't know, I certainly could be wrong.
We get the same thing with SBC heads from the late 70s and 80s smog heads. They just rattle. Whatever you do, though, never use a thicker gasket to drop the compression ratio. That'll make it ping for sure.
It looks like the guys may have some direction on your tester.
Shawn
post #24 of 27 Old 07-13-2013, 05:24 PM
86cj74.2L
86cj74.2L's Avatar
Put the Singh's grove in the head and that will direct the flame towards the outside edge of the cylinder where the flame jet will burn all the unburned hydrocarbons caught between the top ring and the top of the piston.
Those unburned hydrocarbons stuck between the top ring and piston crown is why newer engines have a much less distance between the top ring and piston crown. And is also a major source of detonation. The Singh's groove eliminates that.
post #25 of 27 Old 07-13-2013, 09:54 PM Thread Starter
ninjakid
1987 YJ Wrangler
Ninja,
Shawn
Was wondering about that.
Some quench is better than no quench though right?
9:1 dynamic or static?
.045 quench is what I was aiming for by zero decking the block and using the felpro head gasket to achieve that, I think dcr would be in the 8.8:1 range supposedly.
I can't remember for sure though and seeing how many holes I have in my memory I'm probably mixing it up with something else.
Intersting semi-random fact, my mopar performance handbook (which more focuses on the 4.0, amc v8's and the v8's found in the grand cherokee than the 258) says that 4.0 wrist pins are slightly offset to reduce piston slap when cold and in exchange for more slap when warming up you can flip the pistons for slightly more power and torque.
No mention of quench in that little article in the book.
Understood on the thicker head gasket and I was not planning on doing something like that.
It is something I have been looking into along with some side research on dimpling the ports like a golf ball surface in the rare moments I am headache free.
There are quite a few interesting (and spirited) discussions on speedtalk I'm going through about it.
You've got the people that swear by it and others who say its nothing but a gimmick.
Supposedly it is more suited for low rpms which if true would be great for the 258 assuming I don't do one of my not so rare nowadays moments of stupidity and cut too deep if I decided to do it.
ninjakid is offline
post #26 of 27 Old 07-13-2013, 10:25 PM
86cj74.2L
86cj74.2L's Avatar
Most people talk themselves out if going it.
I did everything to the satty head but the surface tension porting of the intake.
The combination of the valve mod and the Singh's grooving increased torque enough that the second time I started the engine after the head install the PCM went into adaptive mode to relearn all the shift pressures. Within 5 miles all shifts firmed up drastically.
Grooving the intake ports and bumping the CR to 10:1 is my next step. But that head will most likely go on a fresh bottom end not one with 201,000 miles.
post #27 of 27 Old 07-14-2013, 07:17 AM
86cj74.2L
86cj74.2L's Avatar
Oh yea, forgot my claims.
I regularly average 38 to 40mpg for the tank. That's a combined city and rural driving. 31 miles each way to work. This last tank specifically was 38.5mpg and two days I took 422 to work which is all city driving and 36 red lights in 25 miles. Plus each day a 1.2 mile trip to Grammys to run the dogs.
