Help need new gears - JeepForum.com
post #1 of 14 Old 11-19-2002, 09:07 AM Thread Starter
B-Ray
Help need new gears
have a 1983 CJ7 with 2:73 gears running 35" tires. i want to go to 4:56 gears but am being told that i need all this other stuff to make it work. it is currently open differential. anyone with any exp on this please help. randys r&p along with others are quoting anywhere from 700 to 1500 dollars just for parts.
What all do i need to do this gear swap
1995 YJ 2.5L, Rustys 3.5" suspension lift, 1" BL, 1" shackles, Clarion CD player, JL Audio Amp, 2 10's, Tuffy Console, Hella Lights, Independent Offroad Cusyom front and rear bumpers, 32x11.50 Mastercraft M/T, Eagle Alloys,Custom air intake, Flat Fendered.
B-Ray is offline
post #2 of 14 Old 11-19-2002, 11:04 AM
jadams68
jadams68's Avatar
35's with 2.73... your 258 must be cryin' "Uncle!".
Regardless, here's what you need.
- (2) 4.10 ring and pinion set
- (2) Carriers.
- Pinion nuts, carrier shims, ring gear bolts...
The price you had quoted to you is a rip off... I could understand if the labor was involved as well. Make sure you didn't misunderstand what the guy was telling you.
1000+ for everything and labor sounds about right.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 14 Old 11-19-2002, 02:22 PM
MR.CJ-7
I agree with the previous post, except go with the 4.56's or even 4.88's. I am running 4.56's in my CJ with a 3spd auto(no overdrive) and 33's I tach about 3400rpm at freeway speed. I am going to 35's next year and kind of wish I would have gone with the 4.88's. Assuming you still have the D30 front axle any 4.10 and up carrier from a D30 will work. I found one from a TJ and it went right in. In the rear I have the AMC 20. I had a 3.54 stock ratio so I didn't need a carrier change. You may be able to find a real cheap used carrier for the rear. My gear set was $130 for the front and $165 for the rear(if I remember right). I also bought a "master install kit" for both axles to get new seals and bearings(aprox $80/axle I think). I was able to do the labor myself so that was free to me. Good luck
Just my $0.02 worth
Former CJ'er
MR.CJ-7 is offline
post #4 of 14 Old 11-19-2002, 06:53 PM
TG CJ7
How hard is it to put gears in? I've got 2.73 gears in mine too. I also have a narrow track front and rear with 3.54's, laying in the barn. I'd like to those gears in my wide track axles. I have thought about taking them to a shop, but would really like to do it myself. Sounds like B-ray might be interested too.
Thanks
Tim
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #5 of 14 Old 11-20-2002, 04:13 PM
MR.CJ-7
Gears are quite difficult(in my opinion) to put in. There are many different tolerances and torques that have to "played" with to get a good fit. Lucky for me I have a family member who is a jeep mechanic and sets up many gear sets so he looked over my shoulder as I did it, otherwise I would have sent it off to the shop.
Former CJ'er
MR.CJ-7 is offline
post #6 of 14 Old 11-20-2002, 09:56 PM
Jeep Daddy
Jeep Daddy's Avatar
U running a 5 speed? If so, go with 4.56. One previous post is right about the prices on gears and go with the master install kit. The carriers are a little under $100 apiece. You will probably want to go with one piece axles for the AMC 20 too. That will set you back about $300. While you are in there, you may as will install a Detroit Softlocker or Traklock or something like that. What an off road difference.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #7 of 14 Old 11-20-2002, 10:25 PM
rustyCJ
he forgot to mention the bank loan for all the parts: locker, one piece axles, carrier, R&Ps, etc. let alone the labor if you going to have someone else install it all. well unless you one of those jeepers with cash buring a hole in your pocket.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #8 of 14 Old 11-21-2002, 02:01 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Aren't some of the big mail order warehouses offering front and rear "package deals" ? I believe they start at like $399 for a front and rear R&P set with master install kit? They're probably cheap overseas gears but if set up correctly should last a good while. Another option is to watch eBay for used stuff. I picked up my front 3.73 gears and Lockright for my front D44 for $225 and my rear Detroit locker for $300. Also, Xmas is coming up, so I would watch all the mailorder places to start their Holiday Specials. Good luck!
BESRK is offline
post #9 of 14 Old 11-21-2002, 08:43 AM Thread Starter
B-Ray
Here is what i have decided to do.
I am running a T4 tranny btw
Rear: 4.10 gears, one pc axles, ARB Locker I want the ability to turn off, master install kit
Front: 4.10 gears, new carrier, master install kit, no locker
I should be able to purchase all of theses parts for around 1250.00.
have I forgot anything?
B-Ray is offline
post #10 of 14 Old 11-21-2002, 08:57 AM
Jeep Daddy
Jeep Daddy's Avatar
I think you should reconsider your choice of gear ratio. The 4.56 would be a better choice. I run 4.56 in my rig with 33's and it IS geared a little low for my choice of tire, but should I decide to move up to 35's, like you already have, it is the best choice.
You don't want to go back and do it all over again. I thought of the 4.10's as my first choice too, but thought, someday I may want to do some serious 4 wheelin. Since I see you have decided on a locker, you are thinking of serious 4 wheelin. Don't do it twice. Labor isn't cheep.
Also, did you remember to include the air compressor for your ARB? Your price seems a little low to include the air compressor. I found a package deal for gears, master install, ARB front and rear with compressor for $2110. That's everything but the one piece axles for $300. That adds up to $2410. This place has free shipping and if you live outside CA you won't pay tax. Another package deal is $1,709.95 that includes a rear ARB, compressor, gears, MIK, and front Detroit Power Loc. Still need axles.
When I add up all prices of the parts you said, it comes out to $1621. That's for package deal on R&P with install kits $429, ARB $627, Compressor with stuff it needs, $240, Carrier for front Dana 30 $55, and Axles $270.
post #11 of 14 Old 11-21-2002, 09:08 AM
MR.CJ-7
I second that motion
My $.02+Jeep Daddy's $.02=$.04 so were talkin serious cash here!
Good Luck
Former CJ'er
MR.CJ-7 is offline
post #12 of 14 Old 11-21-2002, 10:20 AM Thread Starter
B-Ray
yeap you are correct. my math skills took a day off.
B-Ray is offline
post #13 of 14 Old 11-21-2002, 10:24 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Cool
I havn't read all of the posts but my question would be what is included in the package deal from Randy's?
Two ring and Pinion sets $300.00
Two lockers - Lock Rights - $500.00
Rebuild Kits - $100.00
If you need new carriers, I think you will, add on another $250 or more. If you go with Detroits or ARBs add on another $300 to $500.00.
All this plus shipping.
To upgrade both axles is not a cheap project, Randy's quote is not too far off.
Sorry bout dat, but dig deep for this one.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #14 of 14 Old 11-21-2002, 03:53 PM
duitinmud
Talking blood,sweat and gears
E bay,found 1 piece axles(a deal) and if you need the rest give me a call(D30/AMC20 parts)holding on to the front axles for spares. But try E bay first before you blow some serious coin.It's not all that hard to do, best to drop the axles and do it on the bench or floor, instead of on your back. Lot's of info on the net about the subject. GL
duitinmud is offline
can i run 35s on my cj5 and what gears should i run eckley25 Jeep CJ Forum 7 09-15-2008 09:09 AM
What gears should I buy? nichols077 Jeep CJ Forum 12 05-20-2008 04:31 PM
Gears spk454 Jeep CJ Forum 5 04-12-2008 08:20 PM
Help with gears hardee81cj7 Jeep CJ Forum 6 10-25-2005 01:52 PM
If gears are shot, can you use 4wd gears? cinnamonbelle Jeep CJ Forum 2 03-24-2003 10:44 PM
