help with my jeep - JeepForum.com
post #1 of 7 Old 05-24-2004, 11:52 PM Thread Starter
RickLopez
RickLopez's Avatar
1980 CJ7
help with my jeep
Its an 1980 (O|||O) CJ7
original 304 V8 with performance parts
Auto tranny
Dana 300
http://freehost03.websamba.com/cool-cars/car.htm
2 problems...
When I press the brake pedal all lights (gauges,headlights,...)
turn on. I've been told that the problem may be with the wiring harness located at the sterring column (behing the steering wheel) and grounding. (but how)
The other problem is the front driveshaft.
I notised that the front driveshaft is hitting the trannys oil pan.
My dad says its the engine & tranny mounts.
Does it have to hit at all on extreme articulation?
Im taking it to school soon, so I really need help.
RickLopez is offline
post #2 of 7 Old 05-25-2004, 09:21 AM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
Auto tranny
Dana 300
2 problems...
As for the lights, my guess would be that you have some sort of short. The dash lights are getting power SOMEhow when you press the brake. Either something is wired wrong, or there's a bad connection or bare wire somewhere. You'll have to get a manual and dig through them, and that's no fun.
Your driveshaft definitely shouldn't hit the oil pan. Did you check the motor and tranny mounts? You do have a heavy motor.
I'm no expert on either matter, just chiming in.
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #3 of 7 Old 05-25-2004, 05:40 PM Thread Starter
RickLopez
RickLopez's Avatar
1980 CJ7
Help....
Help......
Help........
post #4 of 7 Old 05-25-2004, 07:23 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Check to make sure your rear light housings are grounded. If the ground is bad, the brake lights will ground through the taillights causing the system to light up. The other problem might be deeper, most CJ's have had massive hacking and modification done to their wiring. You might have to check under the dash for some prior "mods".
jeepdaddy2000 is offline
post #5 of 7 Old 05-25-2004, 09:26 PM Thread Starter
RickLopez
RickLopez's Avatar
1980 CJ7
I checked the rear tail lghts, removed the light bulbs and every thing worked fine. Later I found out that my right tail light had a bad socket and a lightbulb. THANKS for all your help.
But I still need to replace the bad tranny mounts.
post #6 of 7 Old 05-25-2004, 09:28 PM Thread Starter
RickLopez
RickLopez's Avatar
1980 CJ7
is there a way to fix the speedometer readings. I have 35 inch tires.
post #7 of 7 Old 05-26-2004, 03:51 PM
livin2learn
livin2learn's Avatar
You can get a new speedo gear.
http://www.jeeptech.com/javaAps/Speedo.html
http://www.sierrajeep.com/speedome.htm
, I6-258, T-4, 1" M.O.R.E. BL, RE 2.5", Weber Carb, 33" ProComp MT
livin2learn is offline
Jeep Turning Radius (Jeep Turns To The LEFT Great, Not So Much To The RIGHT) Military Jeeper Jeep CJ Forum 8 02-27-2008 10:08 AM
