Help me solve this blasted Pinging.... - Page 6 - JeepForum.com
post #76 of 844 Old 05-09-2013, 01:24 PM
MoC
Originally Posted by TIPPEDITOVER View Post
I never did like either one of you two idiots. Good riddance.
Ha! How about I call you a big stinky internet vagina so you dont like me anymore either...
I love all the meet me in a dark ally bs as well.. Dark alley so he cant see you running away if he actually shows up or dark alley so he cant see that you're just a big stinky internet vagina??
MoC is offline
post #77 of 844 Old 05-09-2013, 01:27 PM
LumpyGrits
Give me 5 minutes in a dark alley with you, we will see who is crying/conscious.
Just another 'keyboard tuff guy' .....
Hey, 'tuff-guy', WHY do you keep posting
LG
LumpyGrits is offline
post #78 of 844 Old 05-09-2013, 01:33 PM
lucdog
lucdog's Avatar
1980 CJ5
Somebody check, is he gone yet. I'd like to come out from my hiding place.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #79 of 844 Old 05-09-2013, 01:35 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm still recovering from "internet vagina".
Hey Extreme, any updates?
Matt
Matt1981CJ7 is offline
post #80 of 844 Old 05-09-2013, 01:42 PM
Davis77Cj
1977 CJ7
"internet vagina"
that is great i love it!
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #81 of 844 Old 05-09-2013, 01:43 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by Matt1981CJ7 View Post
Hey Extreme, any updates...?
Thanks, guys....
Let's see.... where did we leave off before the bullying...?
Dslywalker: Elevation where I live is about 325 feet above sea level, so I assume thatís not an issue.
Bkeese: Jeep idles fine. Beautifully, even.
Although I think it idles a little fast.
I believe the mechanic said he retarded the timing as much as he could.
Also, now that you mention the thermostat, I do remember thinking the ping was a lot better when I picked it up from the mechanic, but got seem to get worse as I drove it. So a new tístat will go in with new plugs/ wires/ cap, etc next week.
I'm still confused if the Q'trac switch should be hooked up to that port on the carb and whether or not my vac advance is hooked up correctly.
Thanks again,
2X
2Xtreme is offline
post #82 of 844 Old 05-09-2013, 01:52 PM
Matt1981CJ7
1981 CJ7
Your Q'trac appears to be hooked up, correctly.
What Shawn and I are suggesting is for you to disconnect the dizzy from the "spark port", plug that port, and find a manifold vac source to connect it to.
The difference between manifold and ported is manifold has full vac at idle, ported has zero vac at idle. Hooking the dizzy to manifold will activate the advance at idle, thereby advancing the timing and cooling the combustion temps. Ported vac was developed for emissions purposes at the expense of engine performance.
Hope this helps,
Matt
post #83 of 844 Old 05-09-2013, 01:58 PM
lucdog
lucdog's Avatar
1980 CJ5
On both of the Quadratrac Jeeps I have/had, the supply is/was hooked up to a small nipple on the intake manifold just behind the carb, not directly to the carb. This was a 304 and a 360. When I installed a 258 in the Jeep I placed a "T" in the vacuum line from the carb to the distributor. You will want full manifold vacuum to the switch/valve in The glove box.
One of the first things I would check is the hold down bolt for the distributor.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #84 of 844 Old 05-09-2013, 02:01 PM
swatson454
1983 CJ7
Originally Posted by Davis77Cj View Post
"internet vagina"
Yeah, that was classic Nothing like a soggy, e-gina with gravel in it and a keyboard for company.
OP,
Since new plugs are on the menu, you might want to drop down a couple of heat ranges and do something like an Autolite 5503 or equivalent.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #85 of 844 Old 05-09-2013, 02:13 PM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ5
I forgive all who have trespassed against me. I also ask for the same forgiveness. I must go now.
TIPPEDITOVER is offline
post #86 of 844 Old 05-09-2013, 02:29 PM
TrebleHook
1979 CJ7
I smell crazy....
1983 CJ8 Scrambler Laredo - 258 MOPAR MPFI/T-5/Dana 300 - 4.10 Dana 44 Rear/Dana 30 Front w/ ARB lockers front/rear - 4" BDS Suspension w/ Fox 2.0 Shocks - Ground Pounder Fab Front Shorty and Rear Spare Custom Bumpers - PSC Steering w/ Borgeson Shaft - 33x10.50 BFG KM2 on 15x8 Mickey Thompson Classic III - Work in progress.....
TrebleHook is offline
post #87 of 844 Old 05-09-2013, 02:30 PM
Davis77Cj
1977 CJ7
Originally Posted by TrebleHook View Post
I smell crazy....
or one heck of a nicotine fit
post #88 of 844 Old 05-09-2013, 02:32 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hey guys.. let's lay off the "vajayjay" word.. we do have several CJ Sisters here in the forum.. let's keep remarks "non-gender".
Tipped.. anything I can help with? Hit me up via PM if you want to. All of us have bad days from time to time.. hate to lose anyone from the CJ Forum..
BESRK is offline
post #89 of 844 Old 05-09-2013, 02:36 PM
Matt1981CJ7
1981 CJ7
I smell crazy....
Take a shower. I get pretty rank after working on my CJ all day, too.
2xtreme, hang in there, man, we'll get it figured out.
What would be really helpful is an overall diagram, or detailed description, of your entire setup. We're looking at bits and pieces in your photos, but don't have the whole picture.
Just a trivial side note, you should put a filter on the intake side of your PCV. Right now, it's just sucking dirty engine compartment air into your engine.
Matt
post #90 of 844 Old 05-09-2013, 02:39 PM
86cj74.2L
86cj74.2L's Avatar
This thread is too long to search if you disconected the vacuum advance and drove it around on just the mechanical advance.
86cj74.2L is offline
