Help me solve this blasted Pinging.... - Page 56 - JeepForum.com
post #826 of 844 Old 07-29-2013, 10:41 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by 2Xtreme View Post
Even if it only occurs under load?
It revs fine when parked.....
Centrifugal is dependent on RPMs.
Vacuum advance is dependent on load. Under heavy load there should be no vac advance at all. Have you ever test driven with the vac advance disconnected and plugged? If so, does it still ping?
Are you sure it's detonation that you are hearing?
Matt
Matt1981CJ7 is offline
post #827 of 844 Old 07-29-2013, 10:52 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Matt
I've had the vac advance disconnected and plugged for quite a while now, trying to figure this out. At least a dozen test drives.... Doesn't help.
At this point I'm not sure of anything....
It usually only does it in once it shifts into second. Sometimes at the end of first gear. Don't know about third gear, as I'm afraid to drive it to the point of shifting to third.
2Xtreme is offline
post #828 of 844 Old 07-29-2013, 12:13 PM
86cj74.2L
86cj74.2L's Avatar
It appears you need to decide on what your next step is with your current engine.
If your rebuilding the 258 you have as a spare to throw in your jeep I'd buy a reman distributor. And make sure its a 13r / 18r advance head. I think I shown you a picture of the hole you can look in to identify it.
If your going with a V8 I wouldn't sweat it.
The side to side play will make your dizzy fire in a jumpy fashion you can see watching in with a timing light.
Did you consider the berrymans chem dip to try and remove the carbon?
86cj74.2L is offline
post #829 of 844 Old 07-29-2013, 12:46 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
My line on the V8 seems ti have withered. So I am picking up another 258 from a member here.
It was running when he pulled it from a Jeep he parted out a while back.
At least that much is known about his engine. My spare - no idea.
Hopefully this one will limp me along until I can do a proper rebuild, or something.
Didn't consider the Barryman's because my initial leakdown test (which I am not 100% confident in) seemed to indicate a blown head gasket between 1 & 2 as well as leaking valves in all cylinders. Maybe I screwed up the test. Had never done one before, so who knows?
I may try another leakdown test with the VC off so I can verify the vales are closed in each cylinder when I do it.
But right now, I've just had it with this engine.
It's obviously gone beyond my experience.
2Xtreme is offline
post #830 of 844 Old 07-30-2013, 05:54 AM
86cj74.2L
86cj74.2L's Avatar
There is a AMC 360 for 100 on Craig's list in the Harrisburg PA area.
Only one state away.
post #831 of 844 Old 07-30-2013, 06:25 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Only a 5 hr drive, one way... lol
2Xtreme is offline
post #832 of 844 Old 07-30-2013, 09:48 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You can run a leak down test on your spare engine just to see if you did it right. Also check the new one also.
John Strenk is offline
post #833 of 844 Old 07-30-2013, 09:51 AM
John Strenk
1976 CJ5
I would love to have that 360 but $100 for the engine and $200 in fuel and toll costs + 11 hour drive....
Almost reasonable...
post #834 of 844 Old 07-30-2013, 10:15 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Doesn't a leak down test have to be done on a warm engine?
Wheel, Fix, repeatů.
2Xtreme is offline
post #835 of 844 Old 07-30-2013, 04:56 PM
86cj74.2L
86cj74.2L's Avatar
Your that far from me? May be he'd meet you in Pittsburg.
It won't fit in the Prius I guess.
post #836 of 844 Old 07-30-2013, 06:02 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
What's a Prius...???
2Xtreme is offline
post #837 of 844 Old 07-30-2013, 06:09 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Ok... Couple questions....
First, I pulled my dizzy apart to check the springs/ weights. The weights seem to be marked differently. One a 10 and one a 16. Is that right?
Also, I noticed my distributor seems to be clocked WAAAY counterclockwise from the photos I've seen. Like 90 degrees or so...
Thoughts?
Either might be nothing..
2Xtreme is offline
post #838 of 844 Old 07-30-2013, 08:04 PM
ASteve
1972 CJ5
Dosn't matter really how it's clocked, but rather that number 1 is on number 1 with regards to the firing order...
Man...I have to say I am so friggin' lost where this thread is...and I'm subscribed and up to date...
SC
ASteve is offline
post #839 of 844 Old 07-30-2013, 08:35 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Welcome to MY world...!!!
2Xtreme is offline
post #840 of 844 Old 07-31-2013, 07:17 AM
scrapman
Thoughts?
Did you check to see if you mechanical advance (the thing with the weights) was moving freely?
You should be able to turn it clockwise (stretching the springs) so that the stop moves from one side to the other side of the 16R opening.
scrapman is offline
