Help me solve this blasted Pinging.... - Page 54 - JeepForum.com
post #796 of 844 Old 07-24-2013, 08:53 AM
John Strenk
John Strenk's Avatar
1976 CJ5
But you cant hear a leak from #1 to #2 just #2 to #1?
If I didn't know anything else I would say the problems are;
#1 Rings
#2 Head Gasket
#3 Rings
#4 Rings and exhaust valve
#5 Intake Valve
#6 Exhaust valve.
John Strenk is offline
post #797 of 844 Old 07-24-2013, 09:41 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
#1 Rings
#2 Head Gasket
#3 Rings
#5 Intake Valve
#6 Exhaust valve.
Not that I noticed. It was VERY evident from #2 to #1...
So, provided I did the test correctly, this engine is shot.....
But again, with 100% leakage how do I get 170 compression numbers?
2Xtreme is offline
post #798 of 844 Old 07-24-2013, 09:56 AM
swatson454
1983 CJ7
It's all-together possible that you messed up on the test so I wouldn't worry about 100% leak-down. The orifice calibrations can mess with your head; especially if it's your first time doing it.
Bleeding air from adjacent cylinders and through the valves, however, is quite telling. Any competent machine shops around you that can build the engine?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #799 of 844 Old 07-24-2013, 10:01 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
There is a good one about a mile from my house.
AND I may have an 'in' through the GF.
Wheel, Fix, repeatů.
2Xtreme is offline
post #800 of 844 Old 07-24-2013, 10:06 AM
John Strenk
1976 CJ5
What vacuum levels wre you running?
I see 10 pages that I would hate read over...
post #801 of 844 Old 07-24-2013, 10:07 AM
swatson454
1983 CJ7
Might be time for dinner and a movie, "just because I love you"
post #802 of 844 Old 07-24-2013, 10:13 AM
86cj74.2L
86cj74.2L's Avatar
My brother had a 440 mopar that ran 10:20's and it had enough blowby to lift the valley pan up into the intake if he didn't have both valve covers vented.
Only other way would be to pull your valve cover to ensure both valves are closed for each cylinder test.
It may just be time for a moment of silence for said motor and hit the do over button with your spare engine.
86cj74.2L is offline
post #803 of 844 Old 07-24-2013, 10:44 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by 86cj74.2L View Post
...Only other way would be to pull your valve cover to ensure both valves are closed for each cylinder test.
I may do this before I pull the trigger.....
2Xtreme is offline
post #804 of 844 Old 07-24-2013, 01:27 PM
LumpyGrits
"The one that really seems odd (to me anyway)is #2 leaking into #1 cylinder"
Time to pull the head, as you have lost the headgasket.
LG
LumpyGrits is offline
post #805 of 844 Old 07-24-2013, 01:37 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by LumpyGrits View Post
...you have lost the headgasket.
At the very least.
2Xtreme is offline
post #806 of 844 Old 07-24-2013, 03:10 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
So I think my plan is to redo the leak down test with the VC off.
If that indeed indicates a shot head gasket, I'll replace it in hopes of getting enough time out of my current motor to replace it with something better - either by rebuilding my spare motor or swapping in a 304.
Sound reasonable?
2Xtreme is offline
post #807 of 844 Old 07-24-2013, 05:43 PM
86cj74.2L
86cj74.2L's Avatar
Sound reasonable?
To me your compression was too even. Though WOT may be different.
post #808 of 844 Old 07-24-2013, 06:42 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Huh?
2Xtreme is offline
post #809 of 844 Old 07-24-2013, 06:46 PM
John Strenk
1976 CJ5
No!
Get a 360...
post #810 of 844 Old 07-24-2013, 07:14 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by John Strenk
No!
Get a 360...
I don't have a line on a 360..
Otherwise I would.....
2Xtreme is offline
