Help me solve this blasted Pinging.... - Page 50 - JeepForum.com
post #736 of 844 Old 07-16-2013, 08:53 AM
swatson454
1983 CJ7
Originally Posted by 2Xtreme View Post
Tell me more about relocating a new PCV port. Where and Why?
And by 'front' I assume you mean here, since the carburetor is rotated 90* on the intake...
Yes. See the PCV port on this one? http://www.summitracing.com/parts/trd-2431
Did you watch that video I posted? I'm wondering if moving the PCV to the active primary side will improve it and actually ingest the vapor instead of blowing it all over the top of your carb.
Probably just reading goat entrails at this point.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #737 of 844 Old 07-16-2013, 09:22 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Did you watch that video I posted? I'm wondering if moving the PCV to the active primary side will improve it and actually ingest the vapor instead of blowing them all over the top of your carb.
My spacer does have a blind hole that I assume is for drilling and tapping for just such a thing.
Big Brother doesn't let us access YouTube from work.
Well, not without some finagling...
I'll have to pull it up on my phone.
2Xtreme is offline
post #738 of 844 Old 07-16-2013, 10:18 AM
86cj74.2L
86cj74.2L's Avatar
What Shawn says makes sense. Plus moving it to the primary side will get it in the air stream. To help move it along persay.
86cj74.2L is offline
post #739 of 844 Old 07-16-2013, 10:35 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Yes anything done (besides making a different 3/8 vacuum port ) is not fixing the problem.
If the intake is a open plenum (even of its not) he can coat a drill bit in grease and drill and then tap a 1/8 pipe tap in there and have his own separate PCV vacuum source.
1/8.... 3/8.... I'm confused.
I assume by 3/8, you are referring to vac line size.
The port location in the picture that Shawn posted looks to be the same size as mine. Spec states 1/4".
Where does the 1/8" come in??
2Xtreme is offline
post #740 of 844 Old 07-16-2013, 11:52 AM
86cj74.2L
86cj74.2L's Avatar
Ok if it says 1/4 inch pipe then so be it.
Did you ask Holley about your rich idle circuit? Beings its susposta be between 1 and 2 turns out. Not 5/8.
post #741 of 844 Old 07-16-2013, 12:06 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
...Did you ask Holley about your rich idle circuit? Beings its susposta be between 1 and 2 turns out. Not 5/8.
No, I didn't.
It seemed unanimous that I needed to rejet or do the modification that Shawn mentioned.
Then, somewhere along the line, I ran into another issue.
Maybe it was the pinging on mech adv, maybe it was the PCV/ leak issue....
To be honest I don't even know where I am at any more... lol.
Right now I can't do anything until I get it to idle smoothly again.
I think it's the carb gasket.
When I get back to town I am going to pull the carb ONE MORE TIME and replace the carb gaskets and add the PCV port to the spacer. Plus replace the carb studs.
2Xtreme is offline
post #742 of 844 Old 07-16-2013, 01:14 PM
86cj74.2L
86cj74.2L's Avatar
No, I didn't.
Your idle issue could be like my problem with the Harley. Too much exhaust gasses in the PCV gas. That will choke (richen it up) your engine.
post #743 of 844 Old 07-16-2013, 01:29 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
True, but it was idling dern near perfect until yesterday......
2Xtreme is offline
post #744 of 844 Old 07-16-2013, 01:36 PM
LumpyGrits
Go back to what you had....
LG
LumpyGrits is offline
post #745 of 844 Old 07-16-2013, 03:00 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
More grasping at straws here....
I was poking around and saw some mentions, here and there, about not having a return fuel line causing overheating.
And also that by not having one, the added pressure in the fuel system could "push the needle valve off the seat and flood the engine with fuel."
Since the Jeep seemed fine out of the gate on my last two runs, and didn't present an issue until it got hot, I got to thinking.
I don't have a return line from my fuel filter.
Probably should.
Hope the tank end is capped.
But my filter is a simple inlet/ outlet.
Any thoughts on this??
2Xtreme is offline
post #746 of 844 Old 07-16-2013, 03:58 PM
86cj74.2L
86cj74.2L's Avatar
Holley's are not that sensitive to fuel pressure as long as you stay below 7psi. Putting a carter high pressure pump (9psi) will eventually blow over the needle and seat.
post #747 of 844 Old 07-16-2013, 04:55 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
OK. Cool on that part.
But what about the overheating?
There is another thread here going on about it...
2Xtreme is offline
post #748 of 844 Old 07-17-2013, 04:43 AM
86cj74.2L
86cj74.2L's Avatar
Do you mean your fuel is overheating?
You got a few issues going on. Stay focused and do not let yourself get side tracked.
Your carb is too rich. Jet it down and drive it. If it effects the idle mixture. Then readjust it. Consider it a bonus.
You got excessive oil coming out your PCV. That's more difficult to handle. Having a stronger PCV draw by relocating it may pull more oil. So make a PCV condenser.
Your cranking pressure is 170psi and you didn't even hold the throttle open. I'm thinking it should be 130-150. (know one mentioned that theirs is as high as yours) which to me is carbon and not 10:1 pistons.
You have detonation just running with the mechanical advance. (Vacuum advance plugged) If your flyweights are not sticking and you can't grab the rotor shaft and move it around to prove the distributor needs replaced.....its back to excessive carbon buildup.
I've already put a small motorcycle carb jet into a rubber tube( as a restrictor) and drove my Saturn around dipping the other end in a jug of water (or -20 deg windshield washer fluid) every time I wasn't at a stop light. I actually installed water injection ( using a 50cc per min at 150psi nozzle) on my satty to keep the carbon gone, since I cleaned it all out while I swapped heads. I have a limit switch that activated it just off idle, (3% Throttle position opening), and rely on manifold vacuum to pull it into the engine.
"Focus Danielson"
post #749 of 844 Old 07-17-2013, 06:39 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
"Focus Danielson"
Good point!
I do tend to get side tracked.
Regarding jetting, I'll have to read back and see what size jets we settled on and get some on order.
I found this separator online. It looks to be a pretty good unit for the price.
http://www.velocityshop.com/product/...ilver_763.html
Good size, sight tube, easily emptied, looks good. One thing I am confused about is that it makes no mention of a filter. And the inlet/outlet lines are right next to each other (which they are on most units), so wouldn't the gasses/ oil just transfer from one line to the other in the space above the canister?
Short of pulling the head, which I would like to avoid, I dont know what more I can do to remove any carbon. I've already run a full gallon of distilled water through the system. Granted that was not under load, and maybe that makes a difference. You mentioned a fuel additive. Recommendation?
I haven't torn into the distributor yet, other than to pull the cap to see if vacuum produced any movement inside, which it did. I will have to pull it apart and take a look at the weights and check the shaft for play.
How much play are we talking about, here?
2Xtreme is offline
post #750 of 844 Old 07-17-2013, 07:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
you would have to look at the internal design but usually there are 'things for the oil to catch on and let the air pass.
It could be anything like a perforated steel plate to something like steel wool. it will catch the oil and and let the air go on by.
I see a trend here,
years of blow by, building up an impressive layer of carbon on the pistons leading to pre-ignition. Higher pressures in cylinder = more blow-by = more carbon buildup = higher pressures...
John Strenk is online now
