Help me solve this blasted Pinging.... - Page 42 - JeepForum.com
post #616 of 844 Old 07-06-2013, 05:52 AM
John Strenk
John Strenk's Avatar
1976 CJ5
i've tried it both ways with no difference I can tell.
I ran ported with the YF and manifold with the BBD
I think the thinking on this has changed as the years
originally all that was ever used was ported vacuum.
When emmisions started to come out, There was a couple years both were used.
Then just manifold vacuum was used and shortly their after, the computer was controlling the timing.
all this between 76 and 84.
John Strenk is offline
post #617 of 844 Old 07-06-2013, 09:42 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Welp, here's the latest.....
Started at 1300 rpm climbed to 1470 over 10 min
Kicked it down, landed at 810 rpm
Hooked up all vac lines, incl. PCV - 1100 rpm
Set Lean Best Idle:
Linkage Side = 7/8 turns out from bottom
Choke Side = 5/8 turns out from bottom
(These results don't seem right to me)
Set idle to 800-ish
Timing jumped to 21.8*
Putting the fender on now, the driving....
Wheel, Fix, repeatů.
2Xtreme is offline
post #618 of 844 Old 07-06-2013, 09:45 AM
swatson454
1983 CJ7
Good job, dude.
Looks like you'll need to drop down 2 jet sizes like 86 said.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #619 of 844 Old 07-06-2013, 09:55 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by swatson454
Good job, dude.
Shawn
Are those number 'normal'?
2Xtreme is offline
post #620 of 844 Old 07-06-2013, 10:02 AM
swatson454
1983 CJ7
They show that your jets are a little large. Ideally, they'd be a little over 1 turn out but not more than a turn and a half.
Shawn
post #621 of 844 Old 07-06-2013, 11:28 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Drove the Jeep about 3 miles so far. Ran a LOT better! Even stopped better!
However.... It's still pinking, or knocking, whatever you want to call it.
Only seems to do it once it shifts into 2nd, and under load. Haven't hit 3rd with it yet, so idk about that.
Don't know if that's a function of where the timing is now, or......
Got a nice leak, too....
2Xtreme is offline
post #622 of 844 Old 07-06-2013, 12:07 PM
LumpyGrits
Sound like ign. 'knock'.
You maybe lug'n the eng. and don't know it. What rpm are you shifting at? I shift at no less that 2500.
Switch to prem. gas(what I run).
LG
LumpyGrits is offline
post #623 of 844 Old 07-06-2013, 01:04 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
LG
Basically, I'm right back where I started hundreds of posts again....
Turns out, it seems to do it at the top end of 1st gear, too.
IDK where the shift points are as far as rpm, it's a TH400.
2Xtreme is offline
post #624 of 844 Old 07-06-2013, 01:15 PM
swatson454
1983 CJ7
You might want to pull about a half a turn out of the vacuum advance. I believe it's an eighth inch allen wrench. Pull the hose off the vacuum advance and stick the long end of the allen wrench into the nipple.
Shawn
post #625 of 844 Old 07-06-2013, 01:35 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
The pig ran out of gas on me while out for my drive.
Had to push the thing up an incline, walk for gas, yadda- yadda, all in the sweltering heat.
Two hours later, I'm home.
But done with it for today.
Yeah, yeah... I know......
Maybe tomorrow....
2Xtreme is offline
post #626 of 844 Old 07-06-2013, 01:42 PM
86cj74.2L
86cj74.2L's Avatar
Shawn
To me, anyway the way your plugs look and the amount of oil in the PCV hose I think you have major carbon buildup inside the combustion chambers. That's not easily removed but possible to get it better using combustion chamber cleaner from BG or what knot. Or spraying a mist of water down the carb throat while bogging the engine at around 1500 rpm for a while.
As for the mixture screws being closed that much. You have a fairly large engine sucking through a small primary. 390/2=195. That air volume is putting one hell of a signal on the metering circuits.
Your Holley hopefully is like all the others in that it has a metering block. Pull it and identify the idle feed restrictor. Then get a piece of stranded copper wire and strip back a few inches and cut off one strand and insert one end in the hole. The other end fold over so the gasket pinches it to hold it in place. That small wire should restrict enough to get you in the sweet spot between 1 and 2 turns out.
86cj74.2L is offline
post #627 of 844 Old 07-06-2013, 02:04 PM
86cj74.2L
86cj74.2L's Avatar
Jetting down the little 390 is needed but I don't think that's going to have any effect on the idle metering circuits. Only way is to juggle air bleeds or make the idle restrictor smaller.
Make a simple PCV condenser to catch the oil blowing into the intake. Go to a hardware store and get a air water separator for a air compressor. Make it a taller one like 6 to 8 inches tall, and ensure it has a cindered brass filter, not a white fiber element. Then buy two barbed hose fittings for your hose diameter.
Their will be a arrow showing direction of flow make sure its pointing to the carb.
post #628 of 844 Old 07-06-2013, 02:18 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
The vac advance and not the timing?
the timing is still at the 21.8 or whatever I posted most recently..
2Xtreme is offline
post #629 of 844 Old 07-06-2013, 02:19 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
I've been thinking about doing this.
Guess now I have to....
And that other stuff you said - might as well have been Portugese... lol
2Xtreme is offline
post #630 of 844 Old 07-06-2013, 02:24 PM
86cj74.2L
86cj74.2L's Avatar
That timing is what is expected if you chose manifold as your vacuum source.
