Help me solve this blasted Pinging.... - Page 41 - JeepForum.com
post #601 of 844 Old 07-04-2013, 03:04 PM
LumpyGrits
Are BOTH idle mixture screws turned out the same amount of turns?
If they are not the same amount, that can cause a stumble.
Also, to lean of an idle mix will cause that stumble, along with to little fuel in the carb fuel bowel for the acc. pump to squirt into the carb's throat.
LG
LumpyGrits is offline
post #602 of 844 Old 07-04-2013, 03:27 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by 86cj74.2L
Did you get smaller jets yet? The ones running a 390 Holley that posted their jet sizes were around 48 to 46 for the primary's. then take the jets you pulled out and put them in the secondaries.
So, what changed that you were able to get your low idle. It seems to just have healed itself while you were going to look at things causing the high idle.
Don't want to touch the jets yet...
I honestly think it was the voltage at the choke that was the issue.
Either that or the centrif. adv. was sticking.
Those are the only two things I did...
Wheel, Fix, repeat….
2Xtreme is offline
post #603 of 844 Old 07-04-2013, 03:28 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
LG
Yes, they are both at the same setting - 1 turn out from bottomed
2Xtreme is offline
post #604 of 844 Old 07-04-2013, 03:53 PM
John Strenk
John Strenk's Avatar
1976 CJ5
LG
OK, so far so good.
Now you can adjust those mixture screws Lumpy is talking about to give you the highest idle speed and then adjust the curb idle bring your idle speed back down.
John Strenk is offline
post #605 of 844 Old 07-05-2013, 05:56 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
OK, so far so good.
This will be Saturdays start.
Once I do this, what is the next step?
Hoping I can drive this thing by next weekend.
Then start addressing the leak that has appeared while doing all of this.....
Made a deposit into the 'emotional bank account' over the Holiday, so I have the entire weekend to do as I wish. Maybe it'll be cool enough to get a little fishing in, too....
2Xtreme is offline
post #606 of 844 Old 07-05-2013, 08:38 AM
John Strenk
1976 CJ5
drive it
post #607 of 844 Old 07-05-2013, 08:45 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
drive it
2Xtreme is offline
post #608 of 844 Old 07-05-2013, 09:46 AM
LumpyGrits
drive it
YUP
Do think those idle mix screws need to come out some.........
LG
post #609 of 844 Old 07-05-2013, 10:09 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
OK, little confused here....
Holley's document states:
"Idle mixture needles are found on the metering blocks. Your carburetor will have four idle mixture needles, one for each venturi, this is known as four corner idle. If you change one idle mixture needle, you are required to change the other idle mixture needles the same amount."
I only have 2 on my carb....
I assume, whether 2 or 4, the procedure is the same.... correct?
2Xtreme is offline
post #610 of 844 Old 07-05-2013, 12:17 PM
86cj74.2L
86cj74.2L's Avatar
Yes you only have two.
I prefer the 4 corner idle circuit carbs myself. But those are on the manual secondaries.
You have time to go to sears and buy their 20 dollar vacuum / pressure gauge. Adjust the screws in or out for highest vacuum. If it is now idling too high lower idle and do it again.
86cj74.2L is offline
post #611 of 844 Old 07-05-2013, 12:58 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Lucky for me, I ordered one from Summit waaaaaaaay back when we started this mess....
2Xtreme is offline
post #612 of 844 Old 07-05-2013, 01:13 PM
86cj74.2L
86cj74.2L's Avatar
Leave the vacuum advance hooked up while tweeking the fuel screws.
The stock jets on that carb are in the 50's. everyone I saw post their numbers were between 48 and 45. Just remember that while driving it. As fat as its going to be. You may drive it and leave off the gas and the idle will drop to almost stalling............
Just be prepared to not have it smooth as butter until you get the jets dialed in.
If you think the fly weights in the distributor were sticking it may be time to consider buying a reman distributor. Then you can make sure it has the 13r/18r advance head. What's another 55 dollars. And this time don't forget to oil the oil wick under the rotor.
And drive it.
post #613 of 844 Old 07-05-2013, 01:35 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
And drive it.
Distributor is next on the under-hood purchase list.
(Dang I'd like to spend some money on this thing for FUN...)
Anyway, as of now, the vac advance is still off.
I should hook it back up when doing the mixture?
2Xtreme is offline
post #614 of 844 Old 07-05-2013, 01:53 PM
86cj74.2L
86cj74.2L's Avatar
Its time to put on the big boy pants and hook up the vacuum advance to whatever you preference is.
The Chevelle use to have the plugs loaded up when I listened to my brother and drove it on the fly weights. The plugs would burn clean and it would run frisky around the time I was parking it. Hooking up the vacuum advance was a god send. Ran 20 degrees cooler in the summer, much more partial throttle torque, and no more run on when I shut it off.
If you choose manifold of the vacuum source don't be afraid when you see 23 to 25 degrees advance when you hook it up. Just lower the idle to where your happy and drive it.
post #615 of 844 Old 07-05-2013, 02:48 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Is there e benefit to one over the other vacuum source, Ported/ Full?
I've read that manufacturers designed in the Ported source for emissions crap.
All of mine is gone.
Errrr.... most of it anyway, by the PO.
2Xtreme is offline
