Help me solve this blasted Pinging.... - Page 37 - JeepForum.com
post #541 of 844 Old 06-28-2013, 08:41 AM
fourbtgait
1930 MK Patriot
Originally Posted by 2Xtreme
After reading and re-reading, I THINK the plan is:
Keep timing where it is at 7*
Pull carb and adjust secondary throttle plates per our discussion above (pert' near closed)
Then set overall idle speed
God, I hope that's correct.....
You are.
fourbtgait is offline
post #542 of 844 Old 06-28-2013, 09:03 AM
86cj74.2L
86cj74.2L's Avatar
How about just adjusting the idle down and not caring about the .020. I never did. Just left the secondary adjusted factory and slapped on carb. Started it adjusted the idle and set fuel screws.
86cj74.2L is offline
post #543 of 844 Old 06-28-2013, 09:08 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
That's how this whole thing started... lol
2Xtreme is offline
post #544 of 844 Old 06-28-2013, 01:32 PM
86cj74.2L
86cj74.2L's Avatar
To me its impossible to set those holes to a generic setting of .020 with no regard for engine type or displacement and expect it to be within 100rpm of your target idle rpm.
post #545 of 844 Old 06-29-2013, 11:03 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Pulled the carb, flopped it over and adjusted the secondaries fully closed. Then opened them up 1.5 turns on the screw which just barely allows light to be visible around the plates.
Also double checked the primaries. Seemed like I had them set to a 'fat' .020",so I closed them a bit.
One thing I noticed when I pulled the carb was that the bottom of the primary plates were wet. Don't k ow if that indicates anything, but figured I'd mention It.
Started it up, and it idled at 1920,which is what Holley states.
HOWEVER....
The dang thing will not kick down off of high idle, no matter what I do....
Ugh...
Wheel, Fix, repeat….
2Xtreme is offline
post #546 of 844 Old 06-29-2013, 11:11 AM
swatson454
1983 CJ7
Choke fully opening when it warms up? Isn't that red (?) lever by the choke a manual kick-down? I haven't had a Holley in my hand in years.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #547 of 844 Old 06-29-2013, 11:18 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Shawn
The red lever is manual kickdown.
Now that you mention it, I don't the the choke was fully opened when warm.
2Xtreme is offline
post #548 of 844 Old 06-29-2013, 11:22 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
I'm thinking 86 may be on to something.
Maybe .020" on the primaries is too much for a relatively 'small' motor for this carb....
Thoughts?
2Xtreme is offline
post #549 of 844 Old 06-29-2013, 12:15 PM
swatson454
1983 CJ7
Thoughts?
That's just a good starting point and something you do your best not to exceed. Less is fine as long as the slots don't disappear or you might end up with an off-idle stumble.
I seriously doubt if there's a thousand rpm there, though.
Shawn
post #550 of 844 Old 06-29-2013, 12:31 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Might be on to something here....
Pulled the carb to close up the primaries and found one of the vac caps had fallen of the carb.
Put it right back I without touching it and fired it up. Using the idle speed screw (all the way out and not touching cam) it is idling at 1100.
Warmed up, it is idling between 840-870.
No vac advance
BUT, when I blip the throttle it stables pretty bad...
2Xtreme is offline
post #551 of 844 Old 06-30-2013, 10:14 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
One other thing I noticed, once it was no longer screaming, is a random slapping sound from the front of the engine...
Don't know if that is due to a fuel issue. But I never heard it before now....
2Xtreme is offline
post #552 of 844 Old 06-30-2013, 07:08 PM
swatson454
1983 CJ7
I hope you didn't miss your ride today.
post #553 of 844 Old 06-30-2013, 07:50 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
I did....
2Xtreme is offline
post #554 of 844 Old 07-01-2013, 03:11 PM
swatson454
1983 CJ7
That sucks, man. I'm sorry.
What happens if you remove the PCV inlet from the carb and plug that port? Do you have a vacuum cap large enough to do that? If not, you can use a short length of the right size hose and thread a screw into the end of it.
If that does the trick, all I can think of doing is trying to find the right (different) PCV valve. This is assuming that everything else is now correct.
Shawn
Edit: I still don't like your PCV configuration but I'm grabbing at straws here. Does your spacer have a port for a PCV inlet? If it were mine, and whether it ran well as is or not, I'd mount my PCV inlet on the spacer and move it to the front of the carb and either plug the inlet at the back of the carb or use it for the power brakes.
post #555 of 844 Old 07-01-2013, 05:17 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Eh.... With as screwed up as it is, it was a long shot anyway.....
EVERY vac port and line is disconnected an plugged right now,
The spacer has a spot to drill and tap it for a port,
It's basically just a recessed hole right now.
Messing with the secondaries got us close.
I'm thinking maybe downy to .010 - .015 on the primaries, and open the secondaries a hair more...???
2Xtreme is offline
