Help me solve this blasted Pinging.... - Page 36 - JeepForum.com
post #526 of 844 Old 06-27-2013, 10:19 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by 2Xtreme
In doing some more digging, I found the following comment from Jeephammer regarding ACAD_Cowboy having the same issue with the same carb:
But following recommendation of Tippeditover, in #26 I have vac advance connected to Full Manifold vac.
So which is right (obviously, I hold some opinions higher than others, here…)?
And does it affect my idle?
Manifold will increase your idle but you make the final idle speed adjustment after you set the timing with the hose disconnected.
Port vacuum will not effect your idle speed. Or should not.
That's not your idle speed problem right now.
Vacuum advance port can be decided later. I've run them both ways.
John Strenk is offline
post #527 of 844 Old 06-27-2013, 10:20 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
That's why I use grease on the gaskets at first in case I have to pull parts off again....
Hmmm.....
2Xtreme is offline
post #528 of 844 Old 06-27-2013, 10:26 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
.... but you make the final idle speed adjustment after you set the timing with the hose disconnected....
So for RIGHT NOW - setting the initial idle, having the vac advance connected to manifold vacuum is correct?
Once I have a decent idle speed I disconnect vac advance and set timing.
Then reconnect and readjust idle...
Does that sound right?
Sorry if I sound like I am getting confused again. But I am...
2Xtreme is offline
post #529 of 844 Old 06-27-2013, 10:46 AM
John Strenk
1976 CJ5
I would set the idle speed with the vacuum line OFF
Set timing with vacuum Line OFF.
Put vacuum line ONN and reset the idle if needed.
post #530 of 844 Old 06-27-2013, 10:55 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Got ya.
Now as far as my current timing at 7*....
Leave it there for setting idle, or no?
2Xtreme is offline
post #531 of 844 Old 06-27-2013, 11:04 AM
lucdog
lucdog's Avatar
1980 CJ5
Is there any chance the throttle cable from the pedal is holding the primary's open?
Will it still idle a 1,600 with the cable off the linkage?
The only other time I've had a hi idle issue was with a BBD and sticking throttle plates.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #532 of 844 Old 06-27-2013, 11:06 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Bill
I've tried disconnecting the cable, with no luck....
2Xtreme is offline
post #533 of 844 Old 06-27-2013, 11:09 AM
firemanjim7
1983 CJ7
Your a real trooper. I would have chunked that carb along time ago. Seems like a real pain in the a$$ to do adjusting on.
firemanjim7 is offline
post #534 of 844 Old 06-27-2013, 11:13 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Stubborn, is more like it... lol
To be honest, it is mostly my inexperience with carbs/ timing that is the problem.
2Xtreme is offline
post #535 of 844 Old 06-27-2013, 11:15 AM
firemanjim7
1983 CJ7
We'll call it "persistent". You'll figure it out.
post #536 of 844 Old 06-27-2013, 04:37 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
One thing I am still unclear on is where I should have my timing set to start this whole process over again.
With it where it is at 7* with no vac advance, it idles high - as we've discussed.
Obviously, I can get the RPMs all over the map my playing with the distributor. The closer to '0', the lower the RPMs....
Just don't want to tamper with the carb if I should back off the distributor....
Thoughts/ recommendations?
Wheel, Fix, repeatů.
2Xtreme is offline
post #537 of 844 Old 06-27-2013, 05:50 PM
86cj74.2L
86cj74.2L's Avatar
With my distributor (junkyard motorcraft out of a Grand Wagoneer) I set my timing as per factory (8*@1600 then checked it at idle of 600 with no vacuum advance) and at idle with no vacuum advance it still shown 7*. I say don't sweat it. Concentrate on your high idle and leave the advance unhooked for now.
I thought for idle that transfer slot measurement was a do not exceed. But its been a while.
The FaceTime offer still stands. Then I can see exactly what your doing. I'll be at work tomorrow by 6pm. No trouble calls ill answer the phone.
86cj74.2L is offline
post #538 of 844 Old 06-27-2013, 06:06 PM
swatson454
1983 CJ7
Ok, we're all missing something really stupid. This ain't right..
Here's what I do in similar situations. Get your favorite liquer (price is a non-issue at this point), Relax alone, if possible to this and I can nearly promise you that it'll come to you.
Laugh if you want. It works
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #539 of 844 Old 06-28-2013, 06:09 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by 86cj74.2L View Post
...I thought for idle that transfer slot measurement was a do not exceed. But its been a while.
The .020" is called out as a dead-on measurement for the primaries.
And (from what I can gather) not-to-exceed exposure of the slot for the secondaries.
2Xtreme is offline
post #540 of 844 Old 06-28-2013, 06:31 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Here's what I do in similar situations. Get your favorite liquer (price is a non-issue at this point), Relax alone, if possible to this and I can nearly promise you that it'll come to you. http://www.youtube.com/watch?v=7aleg9RgBe0
Good stuff, right there!
Wasn't able to get anything accomplished last night, except re-tightening bolts (surprised how loese they were after just one heat cycle ), and fogging the entire engine looking for leaks - still none
I did spend a good chunk of time trying to figure out why it would only crank and not fire all of a sudden..... turns out I knocked the feed line off of the fuel pump when messing with the distributor hold down bolt. What kind of PO doesn't put a CLAMP ON A FUEL LINE????
I was unsure of how the current timing thing, so I didn't go any further. Probably should have, but wanted to be sure the information you guys had given to me took into accout the current timing of 7*
Anyway...
I think, my current confusion is a chicken/ egg thing:
Do I lower the idle by carb tuning, then set timing, or use timing to bring idle down (adjusting if it won't go far enough).
After reading and re-reading, I THINK the plan is:
Keep timing where it is at 7*
Pull carb and adjust secondary throttle plates per our discussion above (pert' near closed)
Then set overall idle speed
God, I hope that's correct.....
2Xtreme is offline
