Help me solve this blasted Pinging.... - Page 34 - JeepForum.com
post #496 of 844 Old 06-22-2013, 08:28 AM
swatson454
1983 CJ7
Originally Posted by 2xtreme View Post
vac advance connected to set idle, right?
10-4
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #497 of 844 Old 06-23-2013, 10:52 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Pretty sure I found the root cause of my intake leaks.
The overall length of the sleeves/ spacers at l over the place. Max variance of .102".
Not sure if I should install/ tweak/ refab individually, per bolt location or try to get a new set and do the same with the new ones.
Obviously, shipping takes time and my buddy's Memorial ride is next weekend.... FML.
Here's a pic. Was tough to get a good one.
The shortest one is one I had to modify to make it work for the location it was in.
Wheel, Fix, repeatů.
2Xtreme is offline
post #498 of 844 Old 06-23-2013, 12:56 PM
86cj74.2L
86cj74.2L's Avatar
Wouldn't a 4.0l header style exhaust with the collector cut off and repositioned be a easier mount than that?
86cj74.2L is online now
post #499 of 844 Old 06-24-2013, 05:10 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Not sure what you are referring to, here.
Pic?
2Xtreme is offline
post #500 of 844 Old 06-24-2013, 05:20 AM
86cj74.2L
86cj74.2L's Avatar
Here
post #501 of 844 Old 06-24-2013, 06:18 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Here
Not sure that would address my issue.
The problem is the difference in thickness between the header flange and the 'shoulders' on the intake.
Regardless of that header I put on there, there will still be a huge mismatch because of the the height of the 'shoulder'
...if that makes any sense
(only on my first cup of coffee...)
2Xtreme is offline
post #502 of 844 Old 06-24-2013, 09:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Makes sense
There would still be mismatched clamping points.
That picture look like something from Stonehedge.
One would think they should all be the same height from intake clamp point the header clamp point though.
John Strenk is offline
post #503 of 844 Old 06-24-2013, 10:28 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
...One would think they should all be the same height from intake clamp point the header clamp point though.
Offenhauser has since redesigned the intake so that the clamping surface is the same as a standard header flange....
Does me no good, since they redesigned it AFTER I bought min....
2Xtreme is offline
post #504 of 844 Old 06-24-2013, 08:28 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Went to the garage fully intent on staying there until the intake was sealed.
Planned on gabbing new sleeves/ spacers. Got all my stock cut. My jig set up. Grabbed the welder - no wire. I love my kids.... Lol.
Figured short of that, MOST of my existing sleeves would work.... IF I had all of the bolts...
One went missing, and is still on the run...
Decided to JB Weld my new sleeves in the mean time. Shouldn't be a problem...
Now my question is , can I use a standard Grade 5 bolt temporarily until I get a replacement?
2Xtreme is offline
post #505 of 844 Old 06-24-2013, 10:37 PM
LumpyGrits
Grade 5 is all you need.
JB will NOT hold up to the exh. heat.
LG
LumpyGrits is offline
post #506 of 844 Old 06-25-2013, 03:57 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
LG
Thanks LG
I don't think the JB has to hold up any longer than getting them torqued down.
The pressure should hold everything in place after than.
I think it's only one that actually needs to be replaced, but I made a few.
Going to pick up more wire anyway and do it right.
Just to be on the safe side.....
2Xtreme is offline
post #507 of 844 Old 06-25-2013, 11:51 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Hoping I will get to fire the Jeep back up tonight.
That is, IF I can find that missing bolt (because the cupped washer is with it ) and IF I can get that 42 piece PS pump bracket back together....
Fingers crossed.....
2Xtreme is offline
post #508 of 844 Old 06-25-2013, 08:22 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
It's Alive....!!!!
Finally got everything bolted back on after fabbing p a couple of spacers.
Fired right up after duel got to it.
Didn't spend the time waiting for the choke to kick off and all of that jazz.
It was 9:30 and the neighbors probably wouldn't have liked that.
I am out of work a little early tomorrow and will go and check for any leaks, etc...
All in all, a good night....
2Xtreme is offline
post #509 of 844 Old 06-26-2013, 05:01 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Nope....
Effing thing is still idling at 1600 +/-.
Not a single intake leak which is good.
But damnit....!!!
2Xtreme is offline
post #510 of 844 Old 06-26-2013, 05:02 PM
swatson454
1983 CJ7
nope....
But damnit....!!!
wtf!
