Help me solve this blasted Pinging.... - Page 19 - JeepForum.com
post #271 of 844 Old 05-30-2013, 09:18 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hmm...I'm not familiar with where the magnetic probe socket is. How close is your mark to the factory stamped TDC mark on the timing cover?
With the light you have, all you need is a confirmed TDC mark on the balancer and the timing cover.
Read the instructions on how to use the advance feature. It's pretty simple and lot easier than trying to read a tape.
Matt
Matt1981CJ7 is offline
post #272 of 844 Old 05-30-2013, 09:29 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by Matt1981CJ7 View Post
Hmm...I'm not familiar with there the magnetic probe socket is. How close is your mark to the factory stamped TDC mark on the timing cover?
Matt
That's pretty far off, almost 2* to 12* depending upon which edge...
John Strenk is offline
post #273 of 844 Old 05-30-2013, 09:32 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Matt
It's the cylindrical thingamajig at the 'clockwise' end of the indicator.
(Thanks John Strenk for the pic).
Just read the manual and the way I understand it, I just set the light to read the 7* someone mentioned a while back and dial in my TDC mark with '0' on the indicator.
Easy Peasy!
2Xtreme is offline
post #274 of 844 Old 05-30-2013, 09:38 AM
John Strenk
1976 CJ5
Easy Peasy!
The new TDC mark right?
Yes, that will give you 7* advance.
post #275 of 844 Old 05-30-2013, 09:40 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Yes, the new TDC mark that I marked on the balancer.
And 7* is what I am shooting for, correct?
2Xtreme is offline
post #276 of 844 Old 05-30-2013, 09:47 AM
John Strenk
1976 CJ5
Good starting point.
At least it should not ping there.
There will be many many opinions on were to set it.
For the record, I'm at 8*
post #277 of 844 Old 05-30-2013, 09:52 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
OK...
Looking forward to getting out of work and getting to it!
2Xtreme is offline
post #278 of 844 Old 05-30-2013, 09:58 AM
Matt1981CJ7
1981 CJ7
Yep, it sounds like you have the program for setting initial.
To chart the centrifugal curve, simply advance the RPMs off idle in 200 increments. Press the advance button on the light until your TDC mark is back to 0. The digital indicator will give you the exact timing at that RPM. Then throttle it up to the next 200 RPM increment and do the same thing.
Matt
post #279 of 844 Old 05-30-2013, 10:02 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Matt
Got it!
2Xtreme is offline
post #280 of 844 Old 05-31-2013, 06:09 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
OK.... Just left the garage.
Don't know what the timing was when I started, but it was waaaay off...
Set the timing to 7* as discussed and the RPMs went up to 1030.
So I charted the mechanical timing from there and this is what I got ( numbers are approximate):
Rpm. Adv.
1200. 10.5
1400. 13
1600. 15
1800. 16
2000. 16.6
2200. 16.5
Took it out for a ride and all was great!
Very little pinging at heavy load.
Then I remembered I didn't hook the vac advance back up. So I figured once I hooked it up the pinging would be gone....
NOT!
Hooked up, pinging is worse. Not as bad as when we started this, but pretty bad.
So that must mean something, right??
[EDIT]
I forgot to mention, it no longer starts right up without fiddling with the accelerator.
Before this I would pump it twice and turn the key = VROOM!
Now I have to play with the peddle while cranking to get it to fire.
Don't know if that indicates anything, but figured I'd mention it......
Wheel, Fix, repeatů.
2Xtreme is offline
post #281 of 844 Old 05-31-2013, 06:38 PM
swatson454
1983 CJ7
Manifold or ported vacuum?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #282 of 844 Old 05-31-2013, 06:41 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Manifold
2Xtreme is offline
post #283 of 844 Old 05-31-2013, 06:49 PM
swatson454
1983 CJ7
Ok, take what I believe is a 1/16th, fairly-long allen wrench, and stick it into the nipple on the vacuum canister and back it out (counter-clockwise) 1 full turn.
There's still a lot left on the table based on your centrifugal numbers but we need to get that vacuum advance out of the way earlier.
Shawn
post #284 of 844 Old 05-31-2013, 07:00 PM
Matt1981CJ7
1981 CJ7
Now that you have your initial set, or at least close, dial the idle down as low as you can go. My 258 idled down to 500 without major hiccups, with the vac acdvance disconnected.
Then re-check your initial timing, and adjust as necessary.
After that, you need to chart your centrifugal out to about 3000. Your engine should be pulling 30+ advance at 3000.
Don't worry about the vac advance until you get your centrifugal worked out.
Matt
post #285 of 844 Old 05-31-2013, 07:11 PM
swatson454
1983 CJ7
Matt,
It looks like his centrifugal hit the wall at around 16 degrees at 1,800 rpm. I'm thinking an advance head swap for more total but stiffer springs to keep the rate down as it still had a little ping left in it. What do you think?
Shawn
