Help me solve this blasted Pinging.... - Page 17 - JeepForum.com
post #241 of 844 Old 05-24-2013, 07:27 AM
swatson454
1983 CJ7
At least you know for sure what your timing is so you can check that off the list. Does that explain your "blasted pinging"?
That still doesn't resolve your plug color issue but it's a step forward.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #242 of 844 Old 05-24-2013, 07:32 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by swatson454 View Post
At least you know for sure what your timing is so you can check that off the list. ...
Hmmm.... confused (again)
I haven't gotten to the step of actually SETTING the timing yet.
2Xtreme is offline
post #243 of 844 Old 05-24-2013, 07:41 AM
swatson454
1983 CJ7
That's ok. At least when you do, you'll know that it actually is what the tape says it is instead of thinking it's at 10* when it's really at 6 or 14, depending on how far off your balancer was and which way it slipped.
Shawn
post #244 of 844 Old 05-24-2013, 07:43 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Shawn
Got it!
Again, thanks for the help.
Looking forward to getting this weekend over so I can get back to it...
2Xtreme is offline
post #245 of 844 Old 05-24-2013, 07:45 AM
swatson454
1983 CJ7
Roger that.
Two words to live by for your upcoming weekend: open bar
Shawn
post #246 of 844 Old 05-24-2013, 07:49 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Roger that.
Shawn
2Xtreme is offline
post #247 of 844 Old 05-25-2013, 08:47 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
OK guys.. I hate to do this to you.
But I am not quite sure how the vacuum is supposed to be addressed for setting the idle.
It normally idles pretty high. So before I can do the idle thing as part of the Initial Timing, I THINK I have to get it down to a 'normal' rpm range.
That being said I have what seems to be conflicting information.
Earlier in this thread, Shawn stated:
.....When you get ready to check the timing and chart out your curve, keep the idle down to 700 rpm or less (vacuum advance unhooked and plugged) to keep any centrifugal advance from coming in too soon and screwing up your work....
But in my other post (above, about the Holley carb), someone responded with this information:
Originally Posted by Jack61 View Post
Vacuum line's need to be hooked up to set idle.
Maybe I am not seeing the differentiation between just setting 'normal' idle and setting it for the Initial Timing....?????
What say you??
2Xtreme is offline
post #248 of 844 Old 05-25-2013, 08:56 AM
swatson454
1983 CJ7
Pull off and plug the vacuum advance to set your timing. The reason you want to keep the idle speed low when you set the timing is because you want to make sure that the centrifugal advance isn't coming in early and screwing you up. It's doubtful that it will but it can happen so just to be sure, keep the idle speed low when you set your timing. Once that's done, hook everything back up and attack the carb settings.
Now where's that wedding bar?
Shawn
post #249 of 844 Old 05-25-2013, 09:05 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Roger that!
I had the vac advance at the distributor plugged, but the line from the manifold was still open.
Could this be why I couldn't get the rpm below 1000?
(I think we discussed that somewhere, but I am in a rush... lol)
2Xtreme is offline
post #250 of 844 Old 05-25-2013, 09:18 AM
swatson454
1983 CJ7
Yep. It's like a submarine: no holes in the ship
post #251 of 844 Old 05-25-2013, 12:54 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by 2Xtreme
Roger that!
If you had and or have a port open on the intake manifold its a vacuum leak. Weather on purpose or by accident.
86cj74.2L is offline
post #252 of 844 Old 05-28-2013, 09:04 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Just a quick update....
I survived the GD wedding (thanks to open bar), so that's a step in the right direction.
Right now it looks like i won't get back to the garage until tomorrow night instead of tonight as I had hoped.
First order of business - reconnect vac advance and set idle speed.
THEN, start the timing thing.
2X
2Xtreme is offline
post #253 of 844 Old 05-28-2013, 09:47 AM
John Strenk
John Strenk's Avatar
1976 CJ5
2X
Um, well, I would..
Remove Vacuum advance, plug hose so no leaks
Set idle speed low as possible
Time engine (idle speed can increase or decrease with changes in timing, lower if it gets to high)
Re-connect Vacuum advance
RESET idle speed if needed.
John Strenk is online now
post #254 of 844 Old 05-28-2013, 10:14 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Oh boy... there goes my head spinning again....
I think I am getting conflicting information on the idle speed thing... maybe..??
2Xtreme is offline
post #255 of 844 Old 05-28-2013, 11:08 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Don't make this more difficult than it needs to be.
Listen to John's, and Shawn's advice. There's no conflicting info, they are both giving you the same advice.
John's step by step is exactly how I do it.
Matt
Matt1981CJ7 is offline
