Help me solve this blasted Pinging.... - Page 15 - JeepForum.com
post #211 of 844 Old 05-21-2013, 11:28 AM
86cj74.2L
86cj74.2L's Avatar
Saying its running better then ever.........how's your pinging doing, since you seem to only have put vacuum advance on manifold?
86cj74.2L is offline
post #212 of 844 Old 05-21-2013, 11:38 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
After doing just the vac change and Cap/ Rotor/ Plugs (oem)/ Wires, there may have been a slight pinging, but if there was I couldn't hear it over the exhaust.
I drove it pretty hard - well, as hard as I dare with no brake lights.... AGAIN! lol.
Definitely more power and running closer to what I am used to from this thing.
2Xtreme is offline
post #213 of 844 Old 05-21-2013, 03:04 PM
86cj74.2L
86cj74.2L's Avatar
I would speculate the tuneup solved most of your detonation. Crossfire from a dead cap and rotor.
post #214 of 844 Old 05-21-2013, 05:11 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yep.
Now let's get that thing screaming like a hyena.
Looking forward to the advance curve.
Matt
Matt1981CJ7 is offline
post #215 of 844 Old 05-21-2013, 05:18 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Probably.
But I could have sworn I did one when I bought it, not too many miles ago.
Wither way, I'm happy with the progress to date and thankful for Jeepforum members!
2Xtreme is offline
post #216 of 844 Old 05-21-2013, 05:19 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by Matt1981CJ7 View Post
Yep.
Matt
Tomorrow night is devoted to garage time....
2Xtreme is offline
post #217 of 844 Old 05-22-2013, 08:14 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Welp, didn't get a lot accomplished tonight.
Everything seemed to be working against me.
Found it difficult to be on both sides of the engine at the same time and the damn fan seemed to always be in the way....
Do I need to remove the fan in order to be able to work around this thing?
It seemed to always catch my ratchet as I spun the dampener, not to mention make it difficult to see what I was doing....
As an aside... when I pulled the plugs to start this procedure, this is what I found (hope you can see the differences in plugs). This is after a less than 3 mile test drive after the tune up/ vac change:
Was hoping to have some numbers to report to you guys....
2Xtreme is offline
post #218 of 844 Old 05-22-2013, 08:23 PM
swatson454
1983 CJ7
Those are new plugs with only three miles on them?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #219 of 844 Old 05-22-2013, 08:48 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Wow. Two normal, 3 fouled one shorted.
How did that happen in 3 miles?
John Strenk is offline
post #220 of 844 Old 05-22-2013, 09:40 PM
Skerr
What made you pull your plugs after only 3 miles?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #221 of 844 Old 05-22-2013, 10:29 PM
86cj74.2L
86cj74.2L's Avatar
Possibly to help turn it over by hand for the timing check.
Do you use or burn oil?
Does your oil on the dipstick smell like gas?
post #222 of 844 Old 05-22-2013, 11:08 PM
dg6772
I recently had this problem with a 5.7 Chevy. Upon a full inspection I determined a bad head gasket between #3 and # 5 cylinders.
Not saying this is your problem but all you've been through is what I went through.
Dave in Muskegon
dg6772 is offline
post #223 of 844 Old 05-23-2013, 02:43 AM
John Strenk
1976 CJ5
Hmmm Maybe that's why he was running a hotter plug....
Here are photos of the plugs I took out (in order, front is to the left):
post #224 of 844 Old 05-23-2013, 04:46 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Yes, those are new plugs w less than 3 miles on them.... ugh
I pulled them for ease of spinning the motor by hand.
John, if you are referring to the plug on the far left being shorted, as in the electrode touching, its not. Just a bad angle for the picture.
(Definitely not as good as some of you guys at taking pics...lol)
The plugs I took out at the beginning of all this (the red ones) are the stock number (985's)
I don't think it burns oil (haven't had a lot of seat time after RMS replacement, so tough to say) and I've never noticed the smell of gas at the dipstick.
So, setting THIS plug issue aside for the moment (we can come back to it), do I have to (or should I) remove the fan for the whole TDC procedure? Going to try to wrap that up tonight.
Thanks again,
2X
2Xtreme is offline
post #225 of 844 Old 05-23-2013, 05:18 AM
John Strenk
1976 CJ5
It's up to you,
I just crank on the crank from under the jeep to keep from hitting the fan. But my fenders have big cutaways. that I can still see the balancer.
