Help me solve this blasted Pinging.... - Page 10 - JeepForum.com
post #136 of 844 Old 05-12-2013, 07:19 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by lucdog
Just a FYI on off the shelf on octane boosters from auto parts stores.
I'll use the brand that says +4 on the can as a example. This stuff does not make 93 octane fuel out of 89 octane, it's only 4/10's. so by adding the proper amount the octane is only increased to 89.4.
Don't waste your hard earned $ on this stuff.
Bill
One bottle as a test was all unneeded to waste my money on.... Lol
I can get 110 (I think) octane, but it's like 8.00/ gal..... Nooooo thanks! Lol
Wheel, Fix, repeatů.
2Xtreme is offline
post #137 of 844 Old 05-12-2013, 08:00 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
My 258 and 360 both seemed to run better on the premium grade, as well. Around here, I think premium is 91 octane.
Bill, thanks for the warning on the octane boosters. I've often wondered if they do any good.
So, without doing the math, you'd have to dump a butt-load of that stuff in your tank to make a difference. Good to know.
Matt
Matt1981CJ7 is offline
post #138 of 844 Old 05-12-2013, 08:22 AM
lucdog
lucdog's Avatar
1980 CJ5
Here's a interesting read.
http://www.exxon.com/USA-English/GFM...y_gas_faq.aspx
Be sure to read the part about how long gas lasts.
I use 87/89 in everything except my Harley Davidson, Honda 400EX ATV, and Stihl 2 stroke tools.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #139 of 844 Old 05-12-2013, 08:48 AM
Skerr
Regarding octane boosters... read the label before you buy. The stuff on our shelves states it can damage the engine over extended use.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #140 of 844 Old 05-12-2013, 09:58 AM
82JeepCJ7
1982 CJ7
I run only non-ethanol fuel in my Jeep. That stuff is the devil!
www.pure-gas.org
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #141 of 844 Old 05-12-2013, 10:19 AM
86cj74.2L
86cj74.2L's Avatar
Go buy a gallon of toluene for octane booster. That's what the gas company's use to boost their numbers.
One of the car magazines even posted a ratio.
86cj74.2L is offline
post #142 of 844 Old 05-12-2013, 12:47 PM
LumpyGrits
Originally Posted by 2Xtreme View Post
Yup!
I plan to post pics of all of the plugs
Keep'm in order so we can see if you have internal eng. issues.
LG
LumpyGrits is offline
post #143 of 844 Old 05-12-2013, 12:50 PM
LumpyGrits
IF you really feel he need for high octane fuel.
Go buy some 110 oct. avation gas.
I the real world. Just buy the highest oct. pump gas you can......
LG
post #144 of 844 Old 05-12-2013, 06:39 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by LumpyGrits View Post
Don't forget a timing light....
I was going to borrow a light, but of the mindset that if you will need it more than once, you should own it.
So I have been doing a little looking around for one that will suit the majority of my needs - jeep and otherwise - AND include a tach function, and found the following.
http://www.summitracing.com/parts/equ-3568/overview/
Thought's/ opinions?
2Xtreme is offline
post #145 of 844 Old 05-12-2013, 06:53 PM
86cj74.2L
86cj74.2L's Avatar
The standard craftsman dial back timing light cant be beat. Plus it works with MSD.
My tach is a cheep summit tach that I set on the battery and hook up with alligator clamps.
post #146 of 844 Old 05-13-2013, 04:42 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by 86cj74.2L View Post
....My tach is a cheep summit tach that I set on the battery and hook up with alligator clamps.
That's a good idea.
Since I just dropped a bunch of cash on the other tools/ testers I'll need for this project.
2X
2Xtreme is offline
post #147 of 844 Old 05-14-2013, 04:54 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
OK, back from a needed vacation and made some needed improvements on the Jeep thanks to you guys. I really needed to see some progress as I was getting pretty bummed out by the whole thing. So here's what I did, and where I am at:
1) Replaced the Cap/ Rotor/ Plugs (oem)/ Wires
Here are photos of the plugs I took out (in order, front is to the left):
I don't know if you can tell in those photos, but they all look like this:
Found this glop under my Cap. I'm assuming it is some sort of dielectric grease or silicone(?). It's a light blue color. Anyone know what it could be?
2) Then, I removed the ported vac advance on the dizzy and connected it to manifold vac - Tee'd into the port on the intake manifold, behind the carb.
3) Took it for a test drive and MAN, WHAT A DIFFERENCE!!
There may have been a slight pinging, but if there was I couldn't hear it over the exhaust. I drove it pretty hard - well, as hard as I dare with no brake lights.... AGAIN! lol.
Definitely more power and running closer to what I am used to from this thing.
Two things I didn't do:
Check for vac leaks (totally forgot because I was excited to try the vac change.....lol)
Swap out the T-stat for the 180* unit.
didn't do this yet because the silicone would have had to set up before I test drove it. And the engine was obviously hot after I drove it.
No work on it tonight. Dinner with the GF's parents.
Still waiting for my Summit delivery.
Thanks again and keep the info coming!!
2X
2Xtreme is offline
post #148 of 844 Old 05-14-2013, 05:19 AM
86cj74.2L
86cj74.2L's Avatar
Those plugs are rich.
post #149 of 844 Old 05-14-2013, 05:52 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Yeah....
I'm confused because prior discussions have indicated pinging being due to a LEAN condition...
2Xtreme is offline
post #150 of 844 Old 05-14-2013, 06:00 AM
gosupes
Make sure to clean all that silicone off. I wouldn't want it restricting the vacuum advance movement somehow.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
