Help me identify what I got! - Page 3 - JeepForum.com
post #31 of 34 Old 11-03-2013, 10:42 PM
Spieg8
1984 CJ8
Originally Posted by epwildcat View Post
How come it won't turn all the way to the stop? Can I adjust that cross bar (name??) any to help?
Gave you a couple things to check in post #28. And there are two "cross bar" things; one is called a drag link (between steering gear box Pitman arm and the passenger wheel steering arm), the other is a tie rod (goes the full length of the axle between passenger side steering arm and the driver side steering arm). You may need to adjust the drag link, but I doubt you need to do anything to the tie rod (tie rod is used to set alignment toe-in/ toe-out).
Also, when the Jeep is steering straight ahead, get out look to see if the pitman arm is pointing directly rearward. If it's slightly left or right, it will limit turning in one direction. This is usually adjusted with the drag link, but can also indicate an indexing error with the gear box/pitman arm.
Spieg8 is offline
post #32 of 34 Old 11-04-2013, 10:14 AM Thread Starter
epwildcat
1981 CJ7
Gotcha, I'll go back and look at that post as well...I guess I missed it, cause I'm not gonna pass on any advice! Thanks Spieg8.
epwildcat is offline
post #33 of 34 Old 11-04-2013, 10:50 AM
fuquayjeep
Does anyone know what kind of engine this jeep has??
http://www.ebay.com/itm/131037460819...0819&viewitem=
fuquayjeep is offline
post #34 of 34 Old 11-04-2013, 10:57 PM
jrussblues
Straight 6
jrussblues is offline
