Help me identify my engine/carb..... - JeepForum.com
post #1 of 2 Old 06-23-2002, 06:56 PM Thread Starter
knowlwk@snowhill.com
1980 CJ7
Question Help me identify my engine/carb.....
Ok, I have a 1980 CJ-7 with what is supposed to be a 258 with 2-barrel carb (according to the VIN), and TF 999 Automatic.
I was hunting around in the books, comparing pictures, and found that I have a Carter YF 1-barrel carb and intake manifold installed (and running well, BTW).
So, now I'm wondering if this is the original motor or has one be transplanted by a previous owner. I can't find any reference to the Carter YF being used on a 258, only the 232.
The code stamped on the engine block is 308C10, so I assume the "C" is the same "C" in the VIN, meaning it is a 258 with a 2-barrel.
I'm thinking someone swapped out a 1-barrel manifold and the Carter YF, perhaps as a cheap fix for a crappy BBD. Also, stamped on the manifold is the number "8.7.78".
Is this a carb/manifold off a '78 I-6? Enquiring minds want to know...
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
post #2 of 2 Old 06-28-2002, 12:36 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
Yes, the Carter YF was used on many 258s AND 232s. I had a factory one in a 1977 CJ-7 I had in the past, and a recent stock 1076 CJ-5 had one as well. If you search a chiltons or Factory Service Manual, you can find a list of what was used, and I have seen the reference to the YF for at least 70s 258s.
4wheeler4CJ is offline
I need to know how to identify my jeeps engine totalcontrol Jeep CJ Forum 2 06-08-2009 09:09 AM
identify engine please? Beninpcb Jeep CJ Forum 4 06-06-2009 10:30 AM
Can anyone help me identify this carb? rkbell Jeep CJ Forum 18 03-27-2009 12:50 AM
Can anyone identify the make of this engine?? SlikRic Jeep CJ Forum 24 11-02-2008 05:52 AM
trying to identify my carb Boycejer Jeep CJ Forum 2 11-12-2006 05:35 PM
