Help me I.D. this 1979 CJ5 carb - JeepForum.com
post #1 of 11 Old 07-16-2013, 07:50 PM Thread Starter
jennkent5454
1979 CJ5
I am looking for a rebuild kit for this carb, can you guys help me ID it?
jennkent5454 is offline
post #2 of 11 Old 07-16-2013, 07:55 PM
John Strenk
John Strenk's Avatar
1976 CJ5
It's a Carter BBD 2 bbl
Pre computer, no stepper motor.
Rebuild kit easy to get and cheap.
Check throttle shaft for play up and down.
John Strenk is offline
post #3 of 11 Old 07-16-2013, 08:03 PM Thread Starter
jennkent5454
1979 CJ5
Thank You,
so I just need to ask for a Carter BBD 2 bbl carb kit?
post #4 of 11 Old 07-16-2013, 08:16 PM
John Strenk
1976 CJ5
Probably need to tell them year and engine size.
If there was a tag on it you should take that in but looking at the front of the carb there appears to be a sticker so that carb might be a replacement carb.
Still, give them the year and engine size also. They should be able to find one.
post #5 of 11 Old 07-17-2013, 03:11 AM
86cj74.2L
86cj74.2L's Avatar
As far as I can tell going to napa you get 1 rebuild kit.
It covers all Carter BBD applications. Be it Jeep or mother mopar. Pick a early to mid 80's jeep with the 4.2l. Heck a jeep Wagoneer with the 4.2l will get you the same kit too. If your picking up what I'm putting down.
86cj74.2L is offline
post #6 of 11 Old 07-17-2013, 08:02 PM Thread Starter
jennkent5454
1979 CJ5
just another picture
post #7 of 11 Old 07-17-2013, 08:34 PM
86cj74.2L
86cj74.2L's Avatar
Pick a CJ year without the stepper say a 1981 or 1982 with the 258. All rebuild kits are in 1 box. Napa has a good kit it has the check balls and the throttle plate screws in the kit.
post #8 of 11 Old 07-17-2013, 08:41 PM Thread Starter
jennkent5454
1979 CJ5
Not sure there is a napa around here but I will check it out. I will see what the other places carry.
What are steppers?
post #9 of 11 Old 07-18-2013, 01:58 AM
86cj74.2L
86cj74.2L's Avatar
What are steppers?
The steppers were a BBD carb with a little stepper motor moving two pins in and out controling the fuel mixture based on what the O2 sensor reading is.
I have a video or two on my YouTube channel of them in operation its "EugeneKingify"
post #10 of 11 Old 07-18-2013, 07:40 AM Thread Starter
jennkent5454
1979 CJ5
Is this the kit I need?
post #11 of 11 Old 07-18-2013, 07:44 AM
CSP
Go into any auto parts store and ask for a carb rebuild kit for a '79 CJ with the 258 and 2barrel carb. Done.
And yes, that is the right kit. Notice that it says that it's for the BBD.
CSP is online now
