help me find a new console!!! - JeepForum.com
post #1 of 7 Old 07-01-2013, 10:54 PM Thread Starter
chief2dogs
1983 CJ7
Hey can anyone suggest a good solid security console that will mount my stereo receiver in it? Here's my issues: I have seat sliders installed on both front seats so that makes my seats sit up another 1". With the console that came with my jeep the seat belts are too snug against this console that measure 10" wide. so when i flip my seats fwd you can imagine what a pain it is to find my seat belts. With this console id of course like a full size cup holder and a solid lock mechanism with good style and armrest.
I've thought about seat belt extenders and removing the plastic shield around the belts, but as a last resort i guess! Thanks!
chief2dogs is offline
post #2 of 7 Old 07-03-2013, 08:56 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to CJ Forum.
Wheelin98TJ is offline
post #3 of 7 Old 07-03-2013, 09:25 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Tuffy makes a good one. it has some straps to hold the seat belts up so they don't lay on the floor when you take them off.
John Strenk is offline
post #4 of 7 Old 07-03-2013, 10:47 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
x2 on the tuffy. my reciever actually kinda pinches right between my seat and the console so its easy to just push the tab in and get it to click. WHen you flip your seats forward the worse thing that happens is they slide back a little, but the strap should hold them up still....
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #5 of 7 Old 07-03-2013, 11:14 AM
only in a jeep cj
Tuffet makes (or made ) the deluxe stereo console in two widths 10" and 8" so the 8 definitly works better in a CJ. If not broken, the plastic housing of the inner belts ( female side) will keep the belt up and in position. It's important not to let it rotate as when the seat is returned back from tne folded position, it bends or breaks the plastic. A metal insert can be made to side in as a stiffener
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #6 of 7 Old 07-03-2013, 11:38 AM
Oxmarqt
1977 CJ7
I concur on the Tuffy. I currently have the 8" wide installed on my '77. Used to have a 10" installed (and it is currently for sale!! $150 you pay the shipping) but I found that it was a little bit of a tight fit. Both front seats just touched the console, which wasn't a problem. The problem was my a$$ was a little too wide for the set up. Caused me to sit a little off center on the seat and that was not comfortable/stable.
If you are "normal size" a 10" is great. If anyone has ever referred to you as 'Husky", "Robust" or "Thick" then go with the 8".
https://www.tuffyproducts.com/p-104-...e-10-wide.aspx
Oxmarqt is offline
post #7 of 7 Old 07-03-2013, 11:47 AM
only in a jeep cj
I found the 10 too wide for the seats and belts and folding them... Not so much a wide rear end, but I guess that would interfere too
Ed
1975 CJ-6 1983 CJ-8
