help me decide drive train for my CJ7 - JeepForum.com
post #1 of 12 Old 07-13-2011, 10:06 PM Thread Starter
Strings72
I have a healthy 289 ford from a 67 mustang thats has k-code heads and a fairly fresh .60 over rebuild and a friend has a cheap amc 360... I also have in my possesion a T-176 and a T-18 so can help me decide what do ruN!!!!!!!!!!
1) 289 with T-176
2) 289 with T-18
3) 360 with T-176
4) 360 with T-18
All votes welcome!
03 TJ: constantly evolving
06 Dodge 2500 CTD 6spd 4x4
Check out my build:
Strings72 is offline
post #2 of 12 Old 07-14-2011, 06:45 AM
Jim1611
Jim1611's Avatar
All would work good. If geared right the 289 might not be as hard on gas as the 360. The 360 could be a bolt in swap but you'll need to change some things for the 289. It would also matter what kind of shape the 360 is in. Does it need a rebuild?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 12 Old 07-14-2011, 06:49 AM
mvigo
mvigo's Avatar
as Jim said, assuming the AMC 360 is in good shape, I would mate that to the T-18
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #4 of 12 Old 07-14-2011, 06:51 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I think the AMC 360 would be a cheaper conversion. At least the bell housing will bolt right on. I'd go with the 360, T-18 combo myself.
John Strenk is offline
post #5 of 12 Old 07-14-2011, 09:02 PM Thread Starter
Strings72
360 would need freshened up. Ford and amc bell housing bolt patterns are the same so no adapters are needed...
Check out my build:
post #6 of 12 Old 07-14-2011, 09:16 PM
yleefox
I would say it depends on your planned usage of the Jeep. I would expect the 360 to have considerably more torque than the 289, if you need that off road for instance. While the 289 might get u a bit more gas mileage as was already mentioned. Furthermore, if passing smog test is a consideration and assuming the 360 is the same year or newer than your Jeep, that might be of importance to you. If you're going to spend a lot of time off road the T-18 has the advantage of lower first gear, however the t-176 might be more enjoyable if street driving is your primary consideration (I have no experience with the t-176, I'm just saying IT MIGHT BE MORE ENJOYABLE).
Something else u might want to consider is the potential value of the 289 to a Mustang restorer. It might put a wad of cash in your pocket that u could use on your Jeep. Just a thought.
Y
83 CJ7 AMC 304, Ford T-18 with Novak Adaptor, Dana 300 TC.
yleefox is offline
post #7 of 12 Old 07-15-2011, 08:25 AM
bkeese
1949 CJ3A
Is this true, never heard that before!
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #8 of 12 Old 07-15-2011, 08:53 AM Thread Starter
Strings72
I have a ford bellhousing and an amc bell housing and the T176 and T-18 both bolt right up to it... so as far as those 2 trannys go its the same
Check out my build:
post #9 of 12 Old 07-15-2011, 09:10 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
When you say: "Ford and amc bell housing bolt patterns are the same"
This usually means one is referring to the actual bolt pattern on the back of the block/engine.
Not the bolt pattern on the transmission side.
AMC & Ford does NOT share the same bellhousing bolt pattern!
LT1CJ7 is offline
post #10 of 12 Old 07-15-2011, 09:13 AM Thread Starter
Strings72
Oh my mistake LT1, I thought we were refering to the trans side
Check out my build:
post #11 of 12 Old 07-15-2011, 01:06 PM
Chewtoy
1976 CJ5
on the 360/T18. Sell the 289 and put the cash into the Jeep.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #12 of 12 Old 07-15-2011, 01:49 PM
gmm141
360 and t18. Keep it in the family
gmm141 is offline
drive train ?'s dtcohen Jeep CJ Forum 1 04-13-2010 12:06 PM
drive train ?'s dtcohen Jeep CJ Forum 2 03-23-2010 04:01 PM
Drive Train Help jsc7002 Jeep CJ Forum 0 09-08-2009 04:01 PM
CJ DJ drive train ? RockJockJack Jeep CJ Forum 2 01-04-2008 08:41 AM
Drive train value of a 79 CJ cbzgt50 Jeep CJ Forum 1 10-11-2005 06:19 AM
