Help! at the junk yard - JeepForum.com
post #1 of 13 Old 10-19-2011, 08:25 AM Thread Starter
slumley1
This may be answered somewhere but I'm on my cell phone so it's hard to search. I wanted to know if an older Cherokee (late 80's??) brake booster would work to convert my 85 cj7 to power brakes. Also, there's a wagoneer. Would the monster size brake booster, the power steering box, or power steering pump from the wagoneer work? What's my best option?
slumley1 is offline
post #2 of 13 Old 10-19-2011, 08:27 AM
sillykid
best option for a booster i know is one out of a yj with power brakes not sure on rest maybe somebody else can chime in good luck!
sillykid is offline
post #3 of 13 Old 10-19-2011, 08:32 AM
AdamH07
1981 CJ8
if the wagoneer has an AMC V8 in it, grab the power steering pump brackets. Trust me, these aren't easy to find and when you do they are usually pricey. Even if you dont need them, someone else will. AMC uses the same bracket on all their V8s.
Anytime I come across those brackets at a junkyard, I snag them.
'81 CJ8 Scrambler
'82 CJ8 Scrambler
AdamH07 is offline
post #4 of 13 Old 10-19-2011, 09:32 AM
levergun
1979 CJ5
I need the ps bracket for my v8.. They are really hard to find. If it has one get it.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #5 of 13 Old 10-19-2011, 10:29 AM Thread Starter
slumley1
Will the AMC V8 bracket work on my Chevy 350 in my CJ7?
slumley1 is offline
post #6 of 13 Old 10-19-2011, 10:30 AM Thread Starter
slumley1
I found a 90 yj and pulled the brake booster and mc :-)
slumley1 is offline
post #7 of 13 Old 10-19-2011, 10:51 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
No, the brackets match the engine. You would need a Chevy bracket set.
I think they just like the idea of if you find them, you may be able to help them out and sell them to them, unless you ever planned to put an AMC V8 into your CJ..
Rick
Cutlass327 is offline
post #8 of 13 Old 10-19-2011, 10:59 AM Thread Starter
slumley1
Gotcha. I have to go back soon so if it's still there when I go back and if it has a V8 I will pick it up and message you levergun.
slumley1 is offline
post #9 of 13 Old 10-19-2011, 11:39 AM
petey156
Whats the value of the AMC power steering bracket??? There were none listed on ebay
petey156 is offline
post #10 of 13 Old 10-19-2011, 11:56 AM
CSP
Going back to the original question, the fullsize Jeep boosters interfere with the rod that goes between the cowl and the grille.
CSP is offline
post #11 of 13 Old 10-19-2011, 12:02 PM Thread Starter
slumley1
I got a 90 yj booster, mc, bracket, and proportion valve. Just trying to figure out what I need to do. I've read that people have to weld the rod that goes to the pedal (I don't know how to weld and don't have a welder). Also, the proportion valve is all the way down on the frame so I guess I'll need new brake line to go from the brakes to the valve that's just below the mc. I saw several tubes that go to the carb air filter and another line that went in to the side of the engine on the yj. I thought it would be a pretty easy swap but now I have doubts that I'll be able to do it.
slumley1 is offline
post #12 of 13 Old 10-19-2011, 12:25 PM
JeepnBlake
$75-125
I've seen them up to 150 and beyond.
Not a bad deal considering they likely cost $50 tops at a JY
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #13 of 13 Old 10-20-2011, 09:34 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Not really if you just post a thread in JeepForum's Wanted Forum. People forget its there all the time and always want to go straight to eBay or aftermarket re-sellers for some reason (especially CJ owners).
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
