Help Jeep wont idle - JeepForum.com
post #1 of 9 Old 04-27-2013, 08:28 AM Thread Starter
INowUnderstand
Help Jeep wont idle
I have the dreaded jeep won't idle problem. So I have a remanuf jasper 258 with non feedback carter carb. Team rushed then ignition nuttered recently with no problems after each. Motor was running pretty good up until a couple of days ago. I fixed a leaking mechanical oil gauge fitting. Jeep was idling fine. Then noticed the TAC door flap was closed so I started looking into the vacuum lines. So I guess I still have a bunch of crap vacuum lines from the emissions stuff still hooked up, not sure it is right due to not even having a feedback carb when I bought it. It was hooked up to one of the vacuum solenoids on top of the valve cover since I didn't really know where it went at the time and it worked for a while. So I decided to try to find a place on a another line and t in. I did and when I restarted it worked. I then started looking at maybe cleaning up some other lines so I disconnected the line going to the 10" vacuum switch and capped it. Restarted and would not idle now. I thought I put it back together the way it was and still the same problem.
So I went to start it this morning and it cranks right up, with choke on and runs good until choke is about almost off and engine is warm, then sputters and dies. Will run good as long as I is above 1500 rpms with the gas pressed. Let off the sputters and dies.
What the heck did I do? Did I pull something off important when I removed the TAC to get a look at the carb and tug on the vacuum lines to trace them. I didn't make a bunch of changes all at once and I thought I got it back together the way it was after. Now it may be just in my head but I did have a slight sputter earlier in the week one time and it did seem to be slightly more rough when cold- this week- but the choke seemed to be coming off quicker than normal- maybe because it has not been as cold? But surely since it was running ok minutes before I have inadvertently done something? Any ideas to start with. I should have time tomorrow or the next day to really look at it, so far I have not, but I couldn't see anything but I was a little panicked and rushed for time when it happened
Thanks
INowUnderstand is offline
post #2 of 9 Old 04-27-2013, 08:47 AM Thread Starter
INowUnderstand
If this sounds like a vacuum problem does it mean it could be off a line coming off CTO? Since it is ok until warm. Am I right am that this doesn't open until 115 f. Or am I confused with something else? I will check with adventures under the hood for diagrams when able
post #3 of 9 Old 04-27-2013, 12:29 PM
86cj74.2L
86cj74.2L's Avatar
The emulsion tubes in the venturi cluster may be clogged. The brass tubes.
86cj74.2L is offline
post #4 of 9 Old 04-27-2013, 12:38 PM
86cj74.2L
86cj74.2L's Avatar
The choke richens thing up after the choke fully opens its lean enough to cause problems.
What are your fuel mixture screws set to?
The flapper valves on the aircleaner should be hooked to manifold source. Then the temp switch in the aircleaner house opens and closed them.
post #5 of 9 Old 04-27-2013, 01:03 PM Thread Starter
INowUnderstand
Ill check that. Have tuned it since I got Was working up to it. Question is would a tuning problem just show up suddenly like this problem did?
post #6 of 9 Old 04-28-2013, 09:24 PM Thread Starter
INowUnderstand
Well I backed my idle mix screws to 5 turns out and jeep started and ran. I have been hearing this hissing noise and started to look and my pcv vacuum line had a big crack in it. Replaced it. Now I am able to turn the mix stews back in. They started at 2.5 turns out. I turned them back in to about 3 now. Now my idle is acting funny. First it was idling pretty good. Then it want to hold high at about 1500 rpms in park instead of going down to curb idle of 1000. Sometimes it would drop by itself, sometimes it would have to be out in gear, then when returned to park the idle would be normal. A little later it was pulsing at a lot lower than the set curb idle both in gear and in park. Maybe more vacuum problems? I slowly working it out.
post #7 of 9 Old 04-28-2013, 10:40 PM
86cj74.2L
86cj74.2L's Avatar
When it idles high can you pull back on the throttle and slow it down?
Is the choke open all the way and not causing the fast idle cam raise idle?
More vacuum leaks. If non of the above.
post #8 of 9 Old 04-28-2013, 10:48 PM Thread Starter
INowUnderstand
Tried to pull back on throttle. All the way back
Choke all the way off
I'm guessing more vacuum leaks. Also I believe the evap canister purge signal is not hooked up right. I slowly getting it all sorted out.
post #9 of 9 Old 05-02-2013, 01:30 PM Thread Starter
INowUnderstand
I started a new thread with different question so for the conclusion see the is thread. Basically egr was on manifold vacuum.
http://www.jeepforum.com/forum/f8/wh...-drop-1515964/
