HELP! Jeep is squirting fluid - JeepForum.com
post #1 of 6 Old 12-03-2009, 02:01 PM Thread Starter
jeepnkal
My jeep is squirting fluid from the engine bay, just right of the motor (if your looking at it from the front of the vehicle). It looks like its coming from a "T" shaped valve, but I have no idea what it is. Its right in front of the oil filter. The liquid is clear and I am sure its not gas.
I cant upload pics, but can send them to someone so you can see what I am talking about.
jeepnkal is offline
post #2 of 6 Old 12-03-2009, 02:24 PM
J_E_E_P_X_J
what kind of fluid is it trans, oil, coolint.
J_E_E_P_X_J is offline
post #3 of 6 Old 12-03-2009, 04:16 PM
bigjoe
1977 CJ7
As posted do you have an idea what kind of fuild it is?
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #4 of 6 Old 12-03-2009, 05:01 PM
kmulholl
1985 CJ8
what year, model, engine ? antifreeze in cooloing system or just water ?
i don't know what fluids are clear in there. gotta be straight water from cooling system.
kmulholl is offline
post #5 of 6 Old 12-04-2009, 07:12 AM
Mike Romain
There are two lines in front of the oil filter on a 258. (You should give us half a clue, the ol' crystal ball is a bit foggy today...)
One of these lines is a small steel gas line, the other is a rubber coolant line.
Mike
Mike Romain is offline
post #6 of 6 Old 12-04-2009, 09:23 AM Thread Starter
jeepnkal
sorry guys, had to work late lastnight. I will go out and take a better look at it for a better description. Thanks in advance.
jeepnkal is offline
ATF or P/S fluid? scooter Jeep CJ Forum 2 01-01-2010 01:37 PM
Brake Fluid & ATF Fluid Questions avking Jeep CJ Forum 1 04-03-2009 11:55 AM
T-18 Fluid Andy5150 Jeep CJ Forum 7 06-18-2008 08:09 AM
T4 fluid ENT Jeep CJ Forum 9 12-12-2007 12:26 PM
D-300 fluid level check and what kind of fluid? NJCJ7 Jeep CJ Forum 1 03-16-2004 08:02 AM
