Help. Its smoking - JeepForum.com
post #1 of 6 Old 06-12-2013, 11:52 AM Thread Starter
jricketts67
1980 CJ5
Help. Its smoking
Well today I was putting my new PS tube fenders on and
1980 cj wouldn't start it clicked... So I jumped it
Then it started leaking white smoke out of the back of the motor on the drivers side
I was wondering what those two problems were
I was wondering also if it is a good idea to replace the 4.2 motor with a 4.0 or 5.0 or just rebuild the 4.2 AGAIN
jricketts67 is offline
post #2 of 6 Old 06-12-2013, 12:07 PM
scrapman
Well, the clicking problem is most likely and bad starter solenoid. It is on the passenger side fender. It will have the positive battery cable going to it. It will look similar to this picture. Need more information on exactly where the smoke is coming from to diagnose your other problem.
scrapman is offline
post #3 of 6 Old 06-12-2013, 12:21 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Sounds like the starter motor is smoking.
OR ayou lost a ground and it's trying to route all the power for cranking through some dinky little wire.
John Strenk is online now
post #4 of 6 Old 06-12-2013, 01:01 PM
LumpyGrits
Dead battery is where I would start.
Get a new starter. You 'smoked' yours with the low D.C voltage.
BTW, attach your battery gnd(-)to one of the starter mounting bolts. Much better hi-amp current flow.
Make DANG SURE, that ALL of your ele. gnds. are tight and CLEAN.
LG
LumpyGrits is offline
post #5 of 6 Old 06-12-2013, 01:28 PM
John Strenk
1976 CJ5
Grounds are the most over looked but important electrical connections
post #6 of 6 Old 06-12-2013, 01:58 PM
John Strenk
1976 CJ5
Dont overlook all the connections
http://www.youtube.com/watch?feature...&v=UeOviW5sR80
